Quick Fix for motorized seat belts???
Are you sure you aren't talking about a Legacy? I've never seen a Loyale with power belts.
On my 91 legacy, under the center console lid was a allen wrench, if you pulled a plug out of the B pillar, (you have to slide the seat around to access it) and stuck the wrench in and cranked it, it would move the belt back to where it should be.
  • 4 weeks later...
  • 1 year later...
If I remember right, the switch for the power seatbelts is part of the latching mechanism in the door.
My latch switch is sporatic on the drivers side but works ok with a screwdriver. Anyone had one of theswe out and adjusted it? Any links to subaru junkyards if I can't adjust it? thanks
Well I found the problem. There is a computer that controls the seat belt motors. On the sedan it is located in the trunk below the speaker panel, right in the center. For some odd reason this one was unplugged. So I plugged it in and they work great.
good job glad it was that easy
