More things working and commin.....
WJM
I replaced the noisy RF wheel beaing....EASY job to do...and now the car is 10000% quiet'r now....
its got some REAL high temp racing brake fluid in it now...Motul DOT 5.1.
Hood is white....gotta smooth it out and make it shinny now.
Comming up april 8th, the RX will be back on a dyno again. It WILL have a wideband hooked up to read AF's on it....I'll do several runs at stock boost....and several on autox boost levels....and I'll be sure to post them up...
Since the SCCA Solo2 National Tour is that weekend...I'll need to throw the RX on a set of scales to make sure it meets the 2600 lb min weight for SM as per rules since its 4wd and turbo. It will be in Autox time....low fuel, and no junk in the car and no driver.
Next planned mod: Super Pro suspension bushings, ALL OF THEM.
