heep70 Posted April 1, 2005 Share Posted April 1, 2005 I had my EA82 dizzy re-curved seeing if there would be any possitive results or if it could be done. WOW, what a difference. Not in hug amounts, but pretty noticable. I have no more piston ping at all and lots more power in the lower and mid range RPMs. It also runs a heck of allot smoother. I had him set it up to have the major part of the power band run inbetween 1350 - 3000RPM, so now there is 17 degrees mech advance and 16 degrees vac advance. I wasn't looking for any raceable results just better, smoother, lower power driving. I think I got it, I am pretty happy with the outcome. I knew these Ea82 weber wagons had more power somewhere. Link to comment Share on other sites More sharing options...
starkiller Posted April 1, 2005 Share Posted April 1, 2005 hmm, will this work on a spi engine? and just who does this kind of work and how much? alan Link to comment Share on other sites More sharing options...
pyromanic Posted April 1, 2005 Share Posted April 1, 2005 You had the dizzy what? Re-curved? Ok, tell us who have no idea what you are talking about (am I the only one?) what that is please. Sure sounds very much like a proceedure many of us EA82 owners might be interested in, no? Thanks, Pyro Link to comment Share on other sites More sharing options...
subie94 Posted April 1, 2005 Share Posted April 1, 2005 does...dizzy have to do with the distributor? of course i don't have one(ej-22) so i don't think i could do the same thing you did. Link to comment Share on other sites More sharing options...
heep70 Posted April 1, 2005 Author Share Posted April 1, 2005 EDITED: to correct what I ment by when the advanced spark is fired. Dizzy = distributor The old kind with the rotor under the cap. Picture the distributor curve as a graph. The horsepower starts out low and as you increase in RPMs (gas peddle) the horsepower increases. At a certian point the horse power peaks and starts to drop off even though you are still giving it gas. You can change how the curve climbs and peaks at different RPMs by changing some parts in the dizzy. All stock dizzies whether OEM or after market are set up with more advance then what is really needed. Ford the Subaru are the worst from what I gather. My Subaru dizzy had 30 degrees of just vac advance stock. This allows for the spark to be thrown way before the piston has reached TDC. By bringing the advance back closer to TDC where the compression is really at gives the car more power. This is done by adjusting the movement in the vac can and using different weighted springs. You tell the guy what your car has, how it is running now and what you want it to run like. Then they build it. I am not sure what spi is. I am a carburetor guy all the way (oldschool). If the dizzy has springs and a vac can (vac advance dizzies) it can be modified. Some dizzies only have the advance springs and no vac cans(mechanical dizzies). They are also candidates. They guy has done many of my 460 Ford dizzies over the years. He has always amazed me with his work. Note: as I said above, the results were pretty noticeable. I did not ask for whip lash results and did not get them. You tell him what you want and he will get it as close as he can. You can only do so much with a stock dizzy and these Subaru dizzies are a bit tough being there isn't any after market parta available. G&M Honest Performance, Steve "The Shoe" Grove Federal Way, Wa Phone253-927-8653 Link to comment Share on other sites More sharing options...
84SOOB Posted April 2, 2005 Share Posted April 2, 2005 What do they charge for the recurve?--Thanks, Brian. Link to comment Share on other sites More sharing options...
heep70 Posted April 2, 2005 Author Share Posted April 2, 2005 $60 for mine and that has been what I was charged for all the other ones he has done. This was his first Subaru distributor he has done. My car was down so I told him to keep it for a few days to see what all ways he could modify these distributor for future purposes. Link to comment Share on other sites More sharing options...
pyromanic Posted April 2, 2005 Share Posted April 2, 2005 I did a Google search, "Distributor Re-curve". Some (not a great lot, but some) interesting reading. Apparently, there are kits availiable for for some cars. Toyota R-22 for example. This whole thing sounds worth looking into further. Link to comment Share on other sites More sharing options...
Ross Posted April 2, 2005 Share Posted April 2, 2005 . This allows for the spark to be thrown way after the piston has passed TDC. I think you mean before. Link to comment Share on other sites More sharing options...
heep70 Posted April 2, 2005 Author Share Posted April 2, 2005 You can get spring kits, but as far as limiting the vac adv is the hard part. The vac cans are not adjustable. Steve had to put a stop pin in it to stop the movemnet at a certian point. He did mention that these distributors are much like a Toyota. Link to comment Share on other sites More sharing options...
heep70 Posted April 2, 2005 Author Share Posted April 2, 2005 I think you mean before. HHHmmmm, When you advance the timing you advancing the spark to fire farther after TDC. That would move the spark forward. Crap, now I am confused :-\ . Link to comment Share on other sites More sharing options...
Ross Posted April 2, 2005 Share Posted April 2, 2005 HHHmmmm, When you advance the timing you advancing the spark to fire farther after TDC. That would move the spark forward. Crap, now I am confused :-\ . When you advance the timing, you bring the spark forward, so that it fires further before top dead centre. This is to allow time for the fuel to combust. Hence BTDC - before top dead centre. Link to comment Share on other sites More sharing options...
heep70 Posted April 2, 2005 Author Share Posted April 2, 2005 Ah yes, you are right. Its Friday and time to do this I fixed it in the thread explianing that. Thanks Link to comment Share on other sites More sharing options...
Ross Posted April 2, 2005 Share Posted April 2, 2005 Its Friday and time to do this Damn, its saturday here. Link to comment Share on other sites More sharing options...
heep70 Posted April 2, 2005 Author Share Posted April 2, 2005 Wow, you are one more day closer to Monday then me. Ha, ha, Cheers Link to comment Share on other sites More sharing options...
Phizinza Posted April 2, 2005 Share Posted April 2, 2005 Do you think this would help me get more power down low on the RPM range for my Brat? I know a place here in South Australia that should be able to help me.. There called SubaModz, so I'm hoping they mean it. I'm going to also look into high comp pistons, I've heard they can help with the low end power too. Can you give us more info on what was done to the dizzy? And what parts were worked on? Thanks Link to comment Share on other sites More sharing options...
heep70 Posted April 2, 2005 Author Share Posted April 2, 2005 Do you think this would help me get more power down low on the RPM range for my Brat? I know a place here in South Australia that should be able to help me.. There called SubaModz, so I'm hoping they mean it. I'm going to also look into high comp pistons, I've heard they can help with the low end power too. Can you give us more info on what was done to the dizzy? And what parts were worked on? Thanks The mechanical advance springs were changed and he had to put a stop pin on the vac can to stop it from advancing so much. I was not there when he did the work and I don't know what springs he used. That is all determind by the guy and what his machine tells him and also how you want it set up. I am sure it will help you out, but keep in mind that things might change when you do the pistons. You might end up having it re-curved again. Just something to keep in mind. Link to comment Share on other sites More sharing options...
Petersubaru Posted April 2, 2005 Share Posted April 2, 2005 17+16=33deg. plus the initial setting??? for total advance..any idea as to what the initial timing is set at....when useing my "back to 0" timing light I get about 54deg when all is in..since my power range is most of the time within the 3200rpm bracket..a change in the curve (10deg less)will definitely take care of the pinging etc.... I had my EA82 dizzy re-curved seeing if there would be any possitive results or if it could be done. WOW, what a difference. Not in hug amounts, but pretty noticable. I have no more piston ping at all and lots more power in the lower and mid range RPMs. It also runs a heck of allot smoother. I had him set it up to have the major part of the power band run inbetween 1350 - 3000RPM, so now there is 17 degrees mech advance and 16 degrees vac advance. I wasn't looking for any raceable results just better, smoother, lower power driving. I think I got it, I am pretty happy with the outcome. I knew these Ea82 weber wagons had more power somewhere. Link to comment Share on other sites More sharing options...
heep70 Posted April 3, 2005 Author Share Posted April 3, 2005 I was running a 9 degrees before, now I can run a 12 degrees easy. Before the work was done ALONE the vac adv was 30 degrees at full open. I just did a run to the Portalnd swap and back. Man, that car runs nice now even with a 2,500 watt Onan and cart in the back. I lost a bit in MPG but I think I might had been enjoying the throttle a little. Link to comment Share on other sites More sharing options...
heep70 Posted April 16, 2005 Author Share Posted April 16, 2005 Anyone else done this yet? I am wondering what your results are and what you went for (performance wise) when you had it done. I really like my results. Shes not a rocket, but she runs really smooth now with better throttle responses. Link to comment Share on other sites More sharing options...
