Ratty2Austin Posted April 2, 2005 Share Posted April 2, 2005 I got a set of 3.5 '98 forester struts.. (one of them was bad, so i only got the RR spring and strut top...) so what is it I need to do to them before I can bolt them onto my impreza L wagon? do I use my imps rear springs, or tops, or.. ? which also means I am looking for a RR forester strut (just the strut.. needs to be used but not broken!) Quote Link to comment Share on other sites More sharing options...
ezapar Posted April 2, 2005 Share Posted April 2, 2005 I used the impreza springs and tops. If I had it to do over again, I woulda hunted down some forester or outback springs for the rear to give it a slight rake. It seems to sit a little higher in the front. I've got a set of spring compressors if you wanna borrow them. Be aware that there are camber adjusting bolts for both front and rear. You can adjust it to match your new struts. I'd advise getting two new rear struts rather than just one. Bite the bullet and have a matching set. Feel free to call me if you have more questions. Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted April 27, 2005 Share Posted April 27, 2005 so for this convert, i need to use the legacy tops and the forester bottoms and springs? Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted April 27, 2005 Author Share Posted April 27, 2005 so for this convert, i need to use the legacy tops and the forester bottoms and springs? yep! use the legacy tops for the rear, and the rest should all bolt in as is... Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted April 27, 2005 Share Posted April 27, 2005 Great, that cuts down on the work a little bit. Quote Link to comment Share on other sites More sharing options...
tailgatewagon Posted April 30, 2005 Share Posted April 30, 2005 so will this work on legacys also. like a 91-94 legacy?? if so hummm Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted April 30, 2005 Author Share Posted April 30, 2005 yep... I belive thats what Noah is putting them on? Quote Link to comment Share on other sites More sharing options...
NoahDL88 Posted May 2, 2005 Share Posted May 2, 2005 Yes i'm putting them on a 90-94 legacy, i'll let you know how it turns out. Quote Link to comment Share on other sites More sharing options...
