will 215's fit on my wagon
i know on my rx with 15"pugs and 205 width tires, the fronts hang out about an inch on both sides of the car, never had any contact between the tires and fenders though.the rear tires are just barely sticking out on the sides. looks hot though, would look better with a wide body kit.
yup, even 195/50R15's stick out about an inch. I think it looks more agressive that way, and I have room to drop the front another inch or so.
215/75's will NOT fit without a lift. I run 205/75R14's on my wagon with a 3" lift kit. I still had to trim alittle fender for it to fit.
-Brian
The only way to know for sure is to test fit a set.
Brian, your wagon is an EA81 and his is an EA82. They have a huge difference in the wheel wells. What doesn't fit yours will probably fit his.
But 205/60/13 on stock rims dont rub.
215/50/13's rub on the inside rear on the subframe during HARD cornering with the car pretty low....ofcourse, those are real R compund race tires and stock 1987 bushings. :banghead:
