wildish Posted April 4, 2005 Share Posted April 4, 2005 New to the Board and need some advise. One of the kids has a 90 legacy with 140K miles and the mechanic says #3 injector went out. I had the #1 Injector replaced about two months ago which solved the problem at that time. The thing is he wants an arm and a leg for the injector. I am mechanically inclined. So how hard is it to change out the injectors? Can someone with a normal layout of tools complete it. Is there any online directions? thanks Link to comment Share on other sites More sharing options...
SevenSisters Posted April 4, 2005 Share Posted April 4, 2005 Check the code displayed to verify (see Legacy777 website). I had a # 3 go out, ran real rough. As I recall, only needed a Phillips screw driver. Oil the new one's o-ring and push in with a 2x4 or something. Cost about $100. Someone jump in here if I'm forgeting something. If it is bad, change the oil too. Link to comment Share on other sites More sharing options...
reddevil Posted April 5, 2005 Share Posted April 5, 2005 Used injectors are about $5 at a U-pull yard. And they tend to be easy to find because they certainly are not an "upgrade" to other cars. Link to comment Share on other sites More sharing options...
Chef Posted April 5, 2005 Share Posted April 5, 2005 Not too tough to replace if I recall. But you'll need to get a new o-ring for it (should be cheap). Used injectors are about $5 at a U-pull yard. And they tend to be easy to find because they certainly are not an "upgrade" to other cars. Link to comment Share on other sites More sharing options...
sregor13 Posted April 5, 2005 Share Posted April 5, 2005 What Year? Or what engine? Thanks Link to comment Share on other sites More sharing options...
