Adjusting rear camber
same here - check bushings/bearings for free play/noise - actually, I need to do my rear suspension bushings :(
damaged/worn out rear struts can also do weird stuff to the rear alignment - you can adjust preload on the rear struts (at least on 4WD models) but that is it
