Hi, can anyone tell me how to find out if the A/C compresor is OK.Well all relays seems workin and clutch on compressor also.A/C system is not exactly full but not empty at all.All A/C hoses are hot.And two weeks ago everthing was fine....
So? Any ideas? :confused:
So the clutch is engaging on it's own? What is the low-side pressure with the system running? If you have dual gauges the high-side pressure would be helpful as well. I have found that the R134a systems start to perform poorly with only a relatively small percentage of the refrigerant missing. Is the A/C fan running? A poorly cooled condenser will cause poor performance as well. I assume the evaporator fan is running?
I'm no expert but I do have a decent book and I will help if I can.
1.clutch is engaging when the A/C switch is pressed
2.System is R12
3.Evaporator fan is running
4.Pressure on the thinner hose is little bit under "FILLED" mark.I got only Gauge A/C filling set and it shows only LOW-FILLED-OVER FILLED
Thanks for your help
Consider fan is running ,but i think it may be already converted...
BUT HOW TO KNOW
http://www.ultimatesubaru.org/forum/showthread.php?t=33889
I appreciate your help
  99obw said:
Can you get R12? If so I would top it off. If not you may consider converting the system. Is the condenser fan running? I can look up the symptoms in my book when I get a chance.
It's really hard to know for sure. It's possible (probable?) that some oil leaked out as the refrigerant was leaking. I would probably put one of the small cans of oil in, 2-1/2" oz in the US IIRC. Be very careful not to get too much oil in it though. The system won't work very well with too much oil. Ask me how I know. :grin:
Yeah ,thats what i am thinking about.And by the way i am now living in US :cool:
And just share your pain :banghead: and tell us what u did with your A/C :grin:
:banana: :banana: :banana: :banana: :banana: :banana: love this smile ...banile?
