Tee Koo Posted April 7, 2005 Share Posted April 7, 2005 How much does EA82 engine weight? How about EA82T or EJ20T? Link to comment Share on other sites More sharing options...
Tee Koo Posted April 8, 2005 Author Share Posted April 8, 2005 I found the weight of EJ20T and it is something like 320lbs (147kg) But how about EA82 (or EA82T)? Link to comment Share on other sites More sharing options...
hooziewhatsit Posted April 8, 2005 Share Posted April 8, 2005 http://www.ultimatesubaru.org/forum/showthread.php?t=28794&highlight=ea82+weigh I recently got an EA82T. A friend and I were able to move it around pretty easy, but it didn't have any of the intake stuff on it. I'd guess maybe 100lbs or so. Link to comment Share on other sites More sharing options...
Tee Koo Posted April 8, 2005 Author Share Posted April 8, 2005 There were even estimation of 200lbs :-\ Any accurate info? Link to comment Share on other sites More sharing options...
NorthWet Posted April 8, 2005 Share Posted April 8, 2005 No accurate info here; though if I had a scale I could weigh an EA81, an EA82 and an EJ22. But, having picked up all three, I would have to go with reportedly-CCRs shipping weight of 150 for the Ea82. By the time you subtract shipping materials (pallet) and add intake, et al, you are probably a bit above that. It is definitely not as light as 100 lbs. The EJ22 is considerably heavier then the EA82... I would guess at least 50 lbs more, maybe 75. Link to comment Share on other sites More sharing options...
Tee Koo Posted April 8, 2005 Author Share Posted April 8, 2005 EJ22 weights ~265lbs (121kg) So therefore 265lbs - 75lbs = around 190lbs Link to comment Share on other sites More sharing options...
breaffyaviation Posted April 9, 2005 Share Posted April 9, 2005 EA 82 stripped of all its bolt on bits 140 pounds. With everything attached ,pushing 180 without the flywheel. Jude Link to comment Share on other sites More sharing options...
Tee Koo Posted April 9, 2005 Author Share Posted April 9, 2005 180 without the flywheel. Thank you for this info Link to comment Share on other sites More sharing options...
WJM Posted April 10, 2005 Share Posted April 10, 2005 according to SUBARU...an EA82 shortblock shipping weight is 45 lbs. All the EJ engines are 110 lbs. Link to comment Share on other sites More sharing options...
breaffyaviation Posted April 10, 2005 Share Posted April 10, 2005 I weighed mine ,Longblock 140. Jude Link to comment Share on other sites More sharing options...
