Engine weights?
No accurate info here; though if I had a scale I could weigh an EA81, an EA82 and an EJ22.
But, having picked up all three, I would have to go with reportedly-CCRs shipping weight of 150 for the Ea82. By the time you subtract shipping materials (pallet) and add intake, et al, you are probably a bit above that. It is definitely not as light as 100 lbs. The EJ22 is considerably heavier then the EA82... I would guess at least 50 lbs more, maybe 75.
