AC clutch=defect
why?
The last time the AC was used was about....5 months ago, and everything worked PERFECTLY and FLAWLESSLY. Then I unplugged the three connectors to the compressor so that it would not kick on and suck my MPGs over the winter months....
Now, time for AC to work again, I hook up the guages, and static wise, everything is perfect.
Hook it all up, push AC on...engine idle up....engine idle down. No AC clutch engage. I stright wire the connector at the relay. Nothing.
Then I wire straight to the positive terminal from the clutch...nothing. Not even a hint of spark or anything.
what gives? Whats the problem? ive never had this issue.
I assume you bypassed the pulse sensor - anyway, letting your A/C system sit unused for months on end is a very sure way to destroy it - it needs to be switched on, at least once a month - I know from an A/C specialist, and I think it is in my 1985 FSM suppliment
what compressor do you have? if it is panasonic, junk it and go hitachi - bigger, slightly heavier, but works 1000x better, and the compressor is rebuildable
fixing the A/C is high on my to-do list now too...
does anyone know about major R-134a compatibility issues?
