Chris4141 Posted April 8, 2005 Share Posted April 8, 2005 Does anyone what the plug gap for my 02 Legacy L 2.5l should be (using OEM NGK plugs)? I cannot find a reference to this in my manual. Also, is there a recommended torque setting when tightening? Thanks in advance for any responses. 1 Link to comment Share on other sites More sharing options...
subie94 Posted April 8, 2005 Share Posted April 8, 2005 not sure if it's the same but on my 94 leg,it's .44(i believe,or +/- 1) don't think you really need to torque them down,tighten till the seals seat then1/4-1/2 turn after.that's the most i know,everything else i ask my mech about to be sure. Link to comment Share on other sites More sharing options...
mwatt Posted April 8, 2005 Share Posted April 8, 2005 Does anyone what the plug gap for my 02 Legacy L 2.5l should be (using OEM NGK plugs)? I cannot find a reference to this in my manual. Also, is there a recommended torque setting when tightening? Thanks in advance for any responses. Correct spark plug gap is shown on the Federal Emissions decal applied to the underside of the hood. Link to comment Share on other sites More sharing options...
wkoepp Posted April 8, 2005 Share Posted April 8, 2005 Don't forget anti-seize goop on the plug threads and di-electric grease on the porcelain part of the plug, it's worth the trouble to avoid other problems later. Link to comment Share on other sites More sharing options...
Strakes Posted April 8, 2005 Share Posted April 8, 2005 Spark plug tightening torque: 13-17 ft/lbs Spark plug gap: 1.0-1.1mm or .039-.043in Link to comment Share on other sites More sharing options...
Chris4141 Posted April 9, 2005 Author Share Posted April 9, 2005 Thanks for the replies! Job was fairly easy, after removing snorkel to air cleaner, battery and washer reservoir to gain access to plug wires. Used a standard spark plug socket with 10" extension on passanger side and 6" & 3" extension on the driver's side. Did not need an elbow, like the endwrech procedure said. Link to comment Share on other sites More sharing options...
