Exhaust Y pipe- welded the Y part
I finally got the Mig ready and thought about the perfect length of the Y pipe, If the volume of the first piece of pipe before the 2-1 collector equaled the volume of the cylinder that fed it????
so by this theory, 1.8l ea82, 2 cylinders per exhaust, 0.9ltr volume per exhaust pipe , at 40mm (1 & 3/4") pipe = 72cm of 40mm pipe gives 904cc of volume
Would this be right??????
Ive seen somewhere before that 29" is the good length, this = 74cm
Ok, i have welded it and put it on my car to test
all i can say so far is its bloody noisy, and has a cool tone (except for a bit of backfire on deacceleration) :brow:
Low end is improved (around 2k) but not sure about top end
would there be much difference between 2" and 2 & 1/4" in noise and power
I want good tone but not loud. i spose that will depend on the muffler
no experience with your car but i would guess 2.25" is too large unless it's a turbo and depending what you're looking for. i've run some larger exhausts on an XT6 and after a point...like 2.5" with no cat i think it looses way too much low end for me.
yep, cut the tube at the flange on the exhaust and welded a bolt head in there but my exhaust gaskets leak and my fuel mixture isn great either
Ive decided to go 2" back from there and i spose i should prob put a cat on, maybe i can get one from the wreckers
