oil pressage gauge install Q
JWX
When appling the teflon tape do not allow it to cover the opening.
Wind it clockwise and only on the threads.
If you apply it properly there is no chance of it getting into the oil passages. I feel it seals better with less torque than pipe dope.
Maybe you had it confused with silicone sealant? When it is used on surfaces such as cam/valve covers or oil pans,
a very thin layer must be used.
