To change those bulbs, you have to remove the instrument cluster, which requires a screwdriver and about ten minutes. Most of which is spent trying to squeeze the cluster between the dash and wheel.
The Check Engine bulb is the same as the gas idiot light bulb.
That's why giving the two bolts that hold the steering column some slack helps a lot.
