EA82 SPFI ignition timing
I need to make sure I'm thinking correctly, so if I'm not please straighten me out. I have mine set at 18 BTDC, because I have a ping and am trying to minimize it. As I understand it that means my timing is 2 degrees "advanced" from manufacturers recommendation, correct? If I set it at 22 BTDC it would be 2 degrees "retarded" from mfrs recommendation and probably make the ping worse, correct?
