[HTi]Johnson Posted April 12, 2005 Share Posted April 12, 2005 Hey, thanks to everyone that helped me get this done. Next up is the hood scoop. That's a close one aint it? Now, I haven't changed the timing...should I? I noticed I lug around 4grand sometimes. Oh yeah, I was going for the "Cleanest Intercooler Install"...but that dude with the front mount owned. [HTi]Johnson Link to comment Share on other sites More sharing options...
subaru_styles Posted April 12, 2005 Share Posted April 12, 2005 good job man , very clean Link to comment Share on other sites More sharing options...
Skip Posted April 12, 2005 Share Posted April 12, 2005 man that sucks hot air - soto speak even when you add a scoop you are going to need something to assist the air flow through it and breathin' the output from the rad fan ain't too kewl, if you catch my drift Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 12, 2005 Author Share Posted April 12, 2005 Yeah I was thinking about that. "THe colder the air going into the turbo, the colder it will be coming out" I'll think of a way to get it into the fender. THanks. [HTi]Johnson Link to comment Share on other sites More sharing options...
Dr. RX Posted April 12, 2005 Share Posted April 12, 2005 Looks like you have Armstrong Power Steering. Link to comment Share on other sites More sharing options...
critical_max Posted April 12, 2005 Share Posted April 12, 2005 Nice job, that does look clean. Can't wait to hear it run Link to comment Share on other sites More sharing options...
Myxalplyx Posted April 13, 2005 Share Posted April 13, 2005 Don't sweat the hot air too much. The hot air really takes it's toll during idle. While moving, it won't be much of a factor if any at all. I tested this out on one of my XT6s at the dragstrip. Running an open air cone style air filter netted a 3-4mph gain in my trap speed vs using a stock air filter setup. The open air cone style filter still had a 1-2 mph gain in trap speed over a stock intake setup with no air filter and ducting going out to the front foglight. Off throttle response 'felt' a tad slower but pickup and top end with the cone style filter was noticable. And this says a lot since these XT6 engine bays get HOT. As for an RX, I noticed a 6ft gain in torque in the midrange through dyno testing. This wasn't tested with a closed hood. However, I did remember reading a SCC (Sport Compact Car) article at one time that had a car lose hp/torque due to the cone air filter sucking in hot engine bay air. The fan that came on was blowing hot air directly on the air filter. I just haven't experienced this with a Subaru. http://www.ultimatesubaru.org/forum/showthread.php?t=27996&page=1&highlight=dyno Link to comment Share on other sites More sharing options...
Snowman Posted April 13, 2005 Share Posted April 13, 2005 A heat shield and a scoop would probably take care of that hot air problem. Or you could get a set of DL headlights and remove the inner set, then stick the cone filter in there. I've always thought that would look pretty wicked. Link to comment Share on other sites More sharing options...
Myxalplyx Posted April 13, 2005 Share Posted April 13, 2005 Oh yeah! I forgot to add that you have a nice looking intercooler setup. What have you done to keep the rear part of the intercooler held steady/support? Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 13, 2005 Author Share Posted April 13, 2005 Actually, I only have the IC mounted at the two points on the sides...i made bushings. I was thinking of running a pipe into the fender and mounting the filter there. [HTi]Johnson Link to comment Share on other sites More sharing options...
Skip Posted April 13, 2005 Share Posted April 13, 2005 Believe who you want and whom ever numbers you want but it is a simple matter of the physics of the situation. Cooler air is more dense and thus contains more 02 & the combustion temps and detonation are a direct function. I believe you have a rad fan on that side. Many after market intake units now come with a partition to keep the engine heat "at bay" so to speak. My filter is located in inner fender area. For your IC to do it's job effectively it must have air flow through the coils. I have a rad fan mounted over mine to assist this flow. Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted April 13, 2005 Author Share Posted April 13, 2005 I will have a hood scoop installed once I get the time to. I know I need to cool the air, why do you think I installed the intercooler in the first place. Link to comment Share on other sites More sharing options...
Free Range Posted April 14, 2005 Share Posted April 14, 2005 J good to see that your ride is still moving under its own power, skip has a valid point, the radiator fan will force air up the spare tire shelf, get some sort of shrouding attached (thick innertube, conveyor belt... Mudrat has some) around the IC to seal the gap between the hood scoop(when you get one) and IC, otherwise, watch out for filling the IC with mud, not to mention that nice big cone filter -N Link to comment Share on other sites More sharing options...
