Super Pro time
THE ORDER IS NOW CLOSED, THE ORDER HAS BEEN PLACED
SUPER PRO BUSHING ORDER:
WJM: 18MM LEADING ROD SET, 24MM CONTROL ARM SET, TRAILING ARM SET
JWX: 24MM CONTROL ARM, REAR TRIALING ARM SET, 18MM LEADING ROD SET
RALLYRUSS: 24MM CONTROL ARM SET, 18MM LEADING ROD SET, TRAILING ARM SET
EDRACH: SPF1383-24K SPF1383-22K
TIZZLE: SPF 2755SK, SPF2239K, SPF138319K, 18MM LEADING ROD KIT, 24mm control arm set, trialing arm set,
when 10am comes around, I will not be taking additional orders...however, those who are on the list (or make it in before 10am) can ammend or correct their ordered items.
I am ordering some super pro bushings for my RX from boxer4racing.com.
I would like to get atleast 4 other people to order some with me if at all possible.
the 18mm leading rod bushings however are only avalible thru Jason Porter of Top Speed...which is where I will be getting those.
SPF1097K - $30
Front Control Arm Lower - Inner Bush
Kit contains 4 Bushings, 2 Tubes
To fit arm with hole ID of 28mm (EA81)
SPF1691K - $60
Kit contains 2 Bushings, 2 Tubes
To fit arm with hole ID of 24mm (EA82)
SPF1098K - $34
Front Strut Bar To Chassis Mount (LEADING ROD)
To suit 17mm outside diameter shaft (Measure!)
SPF2534K# - $TBA (approx $30~$40, these dont officially exist)
To suit 18mm outside diameter shaft (Measure!)
SPF2755SK - $12
Front Sway Bar Link To Lower Arm
1984 - 1994 L12
SPF2239K - $19
Front Sway Bar Link Upper Bush
Sway bar end bush
SPF1383-__K - $10
Front Sway Bar Mount To Chassis Bush
Measure bar diameter, 15-24mm available
SPF1100-__K - $15
Measure bar diameter, Only suits 10/1979 - 1984
SPF1099-__K - $15
Front Sway Bar To Strut Arm "D" Bush
10/1979 to 1984, probably 17mm but 19 also avail. (Measure!)
SPF1144K - $70
Rear Trailing Arm - Bush Kit
Kit contains 8 Bushings, 4 Tubes
Use OE shell
by the way, this will require prepayement to me, and if there is no interest in this by tomorrow morning, the offer will be closed and I will order my bushings. This is not going to be a week long thing before the order goes in.
There will be no BS when I order items for my car that needs a group by in.
That may sound *********************ish...but thats the way its going to be, im tired of ************ing around with this ************.
dude..how much are they??
might be interested in a set for the rally car.
and what bushings does this include?? everything front and rear??
gimme more details...i'll see what i can work out
bump.
Everyone who wants bushings, PM or email me with the list of the Part numbers that you need and how many of each that you need, and how you are planning to pay.
I have to have all the information by 10:00 AM wedesday morning, eastern US time, or you dont get any. Sorry, thats the way its gotta be, applies to me too.
By the way, its going to be a 3 week wait. Its well worth it from what I understand.
I see ive got 7 pms! Deadline approaching.....
Ok, i checked all my PMs, PM'd back those in which I needed to immediatly give/get info from.
I'll respond to the others when I get to work and work up a list of everything.
The order will close in 2.5 hours, its 7:30am Eastern US time right now.
  • 1 month later...
Change of plans. We can get WAY better pricing through Top Speed. We will be getting the bushings though Top Speed now. Right now bushings are in the process of being MANUFACTURED...so lets be a little patient.
  • 3 weeks later...
  • 4 weeks later...
update: the bushings have been ordered as of the beginning of this month...ETA is unknown as they are not in stock and are MAKING THEM as we speak....then they get shipped from OZ to Global (dunno where they are but they are the distributor here in USA for Whiteline and SuperPro) and then to us.
I'll keep you guys updated as I get information.
  • 2 weeks later...
BIG and HUGE thanks to Jason Porter for NOT ordering our stuff!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jason Porter NO LONGER WORKS FOR TOP SPEED.
The new guy here, Tray, and I sat down and we ordered the stuff ourselves.
We expect delivery, HERE, at Top Speed, in 3~4 weeks.
Sorry about the delay, I'll make sure that the prices are rock bottom low since we had to go thru this hassle.
Jesus christ he said he ordered that stuff like 2 months ago.
Yeah.
Every day, we get calls...
"did my stuff come in yet?"
"no...i dont see it here...let me call and find out..."
*we call...to find it was NEVER ORDERED...when Jason told the customer it had been ordered 1~2 months ago...or more.*
"Sorry sir, but it was never ordered...I ordered it just now and it will be here in about 3 days."
"oh...wow....thats...._______________"
Yeah.
One of 3 things that are taking WAY too long to get for my subaru's. At least I can do without this. The differential on my legacy however, is a different story.
WJM--what about that sti key?
STi key? send me a VIN. I'll see about it.
  • 1 month later...
