Loose rear castle nut
I supose ever since i have had my car the rear right 36mm castle has been loose. I thought it was just bearing noise so I had put it off but today when I was geting enthusiastic about doing some repairs, i thied to wiggle the wheel and to my horror it did. The wierd thing is that it had a split pin thru it so the P.O. must not have tightened last time brakes where done. So i thighened it down. Will these wheel bearings be screwed now? Likely to be any hub damage?
tighten it up and see if that cures the matter. if not, then consider the wheel bearing.
make sure all the washers are there, there is a cone washer first, then a flat washer. if these are missing there is the cause of your problem
if you indeend do have to replace the wheel bearing, there is a special socket required to access the inner bearing
the rear bearing on the outside is cone shaped, and the torque of the nut is what holds it all together. so a loose nut will let it wobble a bit. if its tight it should not wobble
Another thing to look for: what appears to be a flat washer that goes between the nut and the cone is really a type of lock washer. If you look closely one side should be stamped "OUT". Be sure you put the "OUT" side toward the nut. It's a spring steel washer and it's not really flat. If it's really worn, consider replacing it.
if there are no stampings on the washer, you will see that it is slightly convex, the convex side will face out and the concave side in, so that it clamps down along the outer diameter of the cone washer
the spacer, when you pack the bearings with grease pack in the space around the outside fo he spacer as well
if the the axle stub can be driven out in the same fashion as a front cv spindle, once you remvoe the rear axle first. there are roll pins on both sides of one axle, drop the diff from the rear hanger and move it sideways to take out he axle
I don't know about you but this seems like good information to archive, if it's not already.
If I was frustrated with a pile of parts, this would help me, get them all assembled correctly.
Is there a torque specification on the castle nut?
Glenn
82 SubaruHummer
01 Forester
  • 2 years later...
