s'ko Posted April 15, 2005 Share Posted April 15, 2005 I was tightening my clutch cable and the 10mm wrench slipped out of my hand in fell into the timing light hole. I started the car and engaged the tranny and it's not rubbing. But how do I get it out? it had to be the 10mm wrench Link to comment Share on other sites More sharing options...
Tcat55371 Posted April 15, 2005 Share Posted April 15, 2005 Try a magnet on a string Link to comment Share on other sites More sharing options...
northguy Posted April 15, 2005 Share Posted April 15, 2005 A magnet on a string will just attach to the flywheel. A magnetic telascoping wand would work better. Otherwise, ... I don't even want to think about it. Link to comment Share on other sites More sharing options...
MilesFox Posted April 15, 2005 Share Posted April 15, 2005 there is a dust cover on the bottom of the bellhousing, you can remove that and the wrench may just fall out Link to comment Share on other sites More sharing options...
BoostedBalls Posted April 15, 2005 Share Posted April 15, 2005 the telescoping magnet should work. If not, take a small hole saw and cut a new "inspection hole" in the bottom of the bell housing. Should be easy to get at that way. Use a rubber stopper to plug the hole or some aluminum tape to cover it. -Chuck- Link to comment Share on other sites More sharing options...
mcbrat Posted April 15, 2005 Share Posted April 15, 2005 I was tightening my clutch cable and the 10mm wrench slipped out of my hand in fell into the timing light hole. I started the car and engaged the tranny and it's not rubbing. But how do I get it out? it had to be the 10mm wrench if it would have been rubbing, you would have known as soon as you started it, since the flywheel is always turning... on the bottom of the bellhousing, there is a small plate held on with 2 10mm bolts. it covers the bottom of the flywheel. it'll be tight, but you might be able to get at those bolts to get that plate off, and see if it comes out through the hole... I usually run w/o the plate for a variety of reasons, and no issues.... might have the jack up the tranny a bit to get at 'em.... PS. if you send me your addy, I can send you a rubber cover..... Link to comment Share on other sites More sharing options...
Bill90Loyale Posted April 15, 2005 Share Posted April 15, 2005 Note: Rubber covers are still available at the dealer for about $5. I bought one a couple months ago. And the junkyard is even cheaper (or should be). Link to comment Share on other sites More sharing options...
ShawnW Posted April 15, 2005 Share Posted April 15, 2005 Those rubber covers are overrated IMO. They have been known to heat up, shrink and fall into the bell housing. They arent really protecting anything either. I think the tool of choice here is a grabber tool if Miles Fox's idea doesnt work. Id remove that plate he refers to and leave it off, it too does no real good. Link to comment Share on other sites More sharing options...
Zefy Posted April 15, 2005 Share Posted April 15, 2005 McBrat on the bottom of the bellhousing, there is a small plate held on with 2 10mm bolts. it covers the bottom of the flywheel. anybody else see the irony??? a magnet would be my first tool to use... Link to comment Share on other sites More sharing options...
82bratavenger Posted April 16, 2005 Share Posted April 16, 2005 Yea the easyest ways to those two bolts on the bottom are with the wrench you dropped. However all good Soobie Mechanics usually have a spare. Great ones have two spares! Just to ask, Are you sure it didn't just fall behind the carb. That is one heck of a whole-shot but then again there is that theory "anything that can go wrong will". Good luck. Link to comment Share on other sites More sharing options...
mcbrat Posted April 18, 2005 Share Posted April 18, 2005 the telescoping magnet trick won't work. I tried using one of themto get something out of the bottom of a door. kept getting stick on the rails, and collapsing. possibly a flexible rod magnet would work. but I'd still try the bolts... Link to comment Share on other sites More sharing options...
baccaruda Posted April 18, 2005 Share Posted April 18, 2005 yeah, it's a great excuse to pick up a spare. (no bowling jokes please.) the first time i tuned up my barracuda when i was (I think) 18 I dropped the condensor screw into the distributor. argh! Link to comment Share on other sites More sharing options...
KStretch55 Posted April 19, 2005 Share Posted April 19, 2005 There's also a certain bit of irony to the statement someone made that "the rubber covers really don't do much". Link to comment Share on other sites More sharing options...
karinvail Posted April 19, 2005 Share Posted April 19, 2005 There's also a certain bit of irony to the statement someone made that "the rubber covers really don't do much". I agree with that one! If the rubber cover was there, this thread wouldn't be here (must go find myself a rubber cover for my car - sounds like something that would happen to me! Ack!) Link to comment Share on other sites More sharing options...
ezapar Posted April 19, 2005 Share Posted April 19, 2005 Those rubber covers are overrated IMO. They have been known to heat up, shrink and fall into the bell housing. They aren't really protecting anything either. I gotta argue with ya Shawn. The difference after going thru a deep mudhole with and without that little cover is bigtime! As in, the end of the throw out bearing or not. I've never seen one shrink and fall in. (not that that means that it never happened before) For a street mobile, don't worry. For an offorader, don't leave home without it. Link to comment Share on other sites More sharing options...
msteel Posted April 19, 2005 Share Posted April 19, 2005 Hi, I'm new here on the message board. But did this same thing a couple of years ago on my '92 Loyale wagon. Except what I dropped in was a steel rod I was using to hold the flywheel in place when tightening the crankshaft pulley. I tried the magnet on a string. I tried the telescoping magnet. I tried the grabber thingy. Then I saw the access plate in a diagram in my repair manual. I took the plate off and the rod fell right out. I did loosen the engine mounts and lift up the transmission off the crossmember first, though. I hope you have success with your wrench! Matthew Steel Link to comment Share on other sites More sharing options...
s'ko Posted April 20, 2005 Author Share Posted April 20, 2005 Will try the cover, thanks for the input. BW Link to comment Share on other sites More sharing options...
