92 FWD Legacy Differential Interchange??
I have a 92 Legacy 2.2 FWD Auto with a lot of play in the drivers side differential output shaft. The differential cage support bearing looks good and the side play of the differential cage is OK. I tried pulling the shaft to check it for wear, but even with my slide hammer it would not come out. I’m thinking the spring clip is bent up out of its grove.
I’m looking for a replacement differential, what years models will bolt up? Thanks
