2wd to 4wd hatch question
ok i did a search and found soem threads on this but in some ways they were a little vague(sp)
ok im thinking about 4wding my hatch and make it my offroad toy now i have i believe what everyone calls the fat ea71, with the starter in the same spot as my ea82.
now 1 of my questions is will i have to keep the 2wd clutch and flywheel or can i put a 4wd 1 on it?also can i go with a 5spd dr or am i gonna have to go with a 4 spd dr?
also will i have to get a ea81 rearend hub or can i use an ea82, as well as a ea82 rear dif?, and can i basically use half of an ea82 wagon driveshaft or am i gonna have to get a hatch 1?and i know ill need to make the brackets to bolt it on
and yes i do plan on doing a lift while i got everything apart.
sorry if this stuff was covered and i just missed the thread that covered it.
and i knwo someone will answer with the enough time and money you can do anything, im just wanting to do this with a little smaller amount of money spent, if its gonna take an outragus amount of cash ill just go buy the nissan frame and running gear i seen for sale and slap the body on that, its complete with tranny and t-case
im sure its a ea71, since i just had to go through trying to track down a disty 4 it. ill double check today to make sure the starter is in the same exact spot as the other 1. but im pretty sure it is
yeah i found those links, morgans especially was very informative, but i didnt see anything rellating to if ea82 stuff would fit
the hatch takes a difft length driveshaft than the EA82 sedan or wagon, so a 4sp D/R out of a hatch (w/ axle) is your best option, unless you want to have it fabbed
BTW - late model EA71's have the starter on the side, so it may very well be an EA71 - in which case I would probably swap an EA81 (or EA82) in soon
im not looking ot do a motor swap in this car, the ea71 runs real strong and can burn fairly new tires in 3 gears, so i think it ould be kinda dumb to swap out the motor, besides if im not beating the crap outta this car offroad ill prob just beat the crap out of it on the road, i just prefer to make it a mud fun car.
