Plug wires
NGK's are the best for Subes, IMO.
Besides being the correct legnth, they snap onto the plugs like no other brand I've ever tried. Plus, they look cool in blue!!
The others just aren't quite up to par. Even the best of them pale in comparison. When you consider that NGK's are priced about the same as the "premium" grade aftermarket wires, it's really a no brainer.
good luck, John
Last set I bought were made by Wells; good brand and they were the correct length. At first, as Alleyboy has noted, the boots didnt fit on that tight. Well they have since shrunk up and fit nice :)
I might have to try those NGK ones next; they sound good. Ive used the 8mm custom cut ones noted above; worked great on my 472ci V8. Took a while to cut, boot, and crimp them all however!
