Phaedras Posted April 21, 2005 Share Posted April 21, 2005 Has anyone tried to swap out their OEM or OEM-style fuel filter for something else? I was wondering if there are higher-flowing or more efficient-filtering ones out there. I'm guessing technically you could use a wide array of filters since the technique is the same across the board. For example, you apparently can use newer model VW GTI filters on older Audis, and this supposedly is an improvement. Link to comment Share on other sites More sharing options...
northguy Posted April 21, 2005 Share Posted April 21, 2005 Snowman (PHD in Voodoo Engineering) has installed a high capacity fuel filter that appears to be for marine application or for a much larger motor. It does a better job of separating water from the fuel also. PM him for details. Link to comment Share on other sites More sharing options...
erik litchy Posted April 21, 2005 Share Posted April 21, 2005 your engine isnt turbo i cant imagine it needs more fuel than the stock filter provides? Link to comment Share on other sites More sharing options...
Phaedras Posted April 21, 2005 Author Share Posted April 21, 2005 I do have a massive open cone filter, so I'm thinking I have a bit more material I could burn, albeit not much. Link to comment Share on other sites More sharing options...
Snowman Posted April 21, 2005 Share Posted April 21, 2005 I'll try to get a picture up of my fuel filter setup. It's a WIX spin-on fuel filter and water separator (with a drain on the bottom). The filter mounting base was $27 and the filters are around $10. WIX says it's good for up to 400 hp, so I think it just might meet our fueling needs:rolleyes: . It's primarily designed for large marine inboard engines, but can be used on just about anything, gas or diesel. In all honesty, you should not need more fuel than the stock filter can flow. Since it's a pressure-regulated bypass system, most of the fuel that goes through the filter just gets pumped back to the tank anyway. That said, I went with my filter setup for two reasons: It's as easy to change as an oil filter, and I've had lots of trouble with condensation in the fuel tank building up, so I needed the water-separating capacity. Link to comment Share on other sites More sharing options...
KStretch55 Posted April 21, 2005 Share Posted April 21, 2005 As large as the fuel filters on these are I'd be really surprised to see one actually clog. Has anyone ever had one they could honestly say was the root of a fuel flow problem? The one on my Ford F250 and a Ranger that I used to have are around the same size, if not slightly smaller, and the Ford wizards all say they'll last the lifetime of the vehicle. Unless you put dirt in the system or something. Link to comment Share on other sites More sharing options...
Snowman Posted April 21, 2005 Share Posted April 21, 2005 As large as the fuel filters on these are I'd be really surprised to see one actually clog. Has anyone ever had one they could honestly say was the root of a fuel flow problem? The one on my Ford F250 and a Ranger that I used to have are around the same size, if not slightly smaller, and the Ford wizards all say they'll last the lifetime of the vehicle. Unless you put dirt in the system or something. I have yet to see an FI subaru filter actually clog. (It's a very common problem on the carbureted models though.) Lasting "the lifetime of the vehicle" when it's a Ford, is not very long.... j/k Link to comment Share on other sites More sharing options...
KStretch55 Posted April 21, 2005 Share Posted April 21, 2005 As much as I like my Fords, you have a point!! Most people consider the normal life of a vehicle to be from new to first engine overhaul. Most would be around 80K, just when most Soobies are starting to loosen up and get good!! Link to comment Share on other sites More sharing options...
