seb Posted April 21, 2005 Share Posted April 21, 2005 Just replaced rear rotors and pads on my Legacy Wagon. Everything seemed fine until yesterday when I started hearing a squeal on the highway. Especially when turning left. Upon closer inspection my rear left break was very hot. Not the caliper but the center drum section which houses the e-brake. The wheel still rotated freely when pushed in neutral. Now did I miss doing something with the e-brake when I replaced the disks? Do they need some sort of adjusting or again need some lube? The handbrake doesn't feel tight at all... Thanks for any info! Sébastien Link to comment Share on other sites More sharing options...
lmdew Posted April 21, 2005 Share Posted April 21, 2005 Yes, they should be adjusted to the disk. Your old disk had some wear and if the E-brake shoes were adjusted out, they will be to tight on the new rotors. I'd pull it back off and check the condition of the brake shoes and drum/rotor. Adjust them and you should be OK. Link to comment Share on other sites More sharing options...
seb Posted April 21, 2005 Author Share Posted April 21, 2005 Thanks! If I understand well, there are two types of adjustments then. One right at the drum and the other for the cable lengths in the console. Can the adjustement at the drum be done without removing the disk/drum assembly? Seb. Link to comment Share on other sites More sharing options...
SevenSisters Posted April 21, 2005 Share Posted April 21, 2005 I believe you can back off the adjuster screw through a slot in the backing plate. Since you've cooked the bearing grease, expect a "snow tire" noise to develope in the rear. Then it's time for a new bearing. Link to comment Share on other sites More sharing options...
