You'd be going from tires 24" in diameter to 26.25", if my calculations are accurate. So your speedometer will be off by 9%, and you'll be an inch higher up. You *could* mount pimpin' 205/55R15 tires on the Forester rims to keep the speedo accurate.
The WRX tire/wheel set-ups work well on the Legacy because they are not that much taller just a little wider., but they usually fit unless you have a heavy load in the bakc
I am almost willing to bet that the Forester tires will rub. The wheels will be the same but the tires are too big for the wheel wells.
