Water in oil
Is there anything special i should do to get the water out of my engine? I'm going to drain it out and put some new oil in tomorrow. I can't get seafoam here, but will this be enough of should i consider additives or do something special? Someone put water down the dipstick...
Thanks in advance.
  heep70 said:
Try some Marvel Mystry Oil along with the new oil. (8oz). That will help chase the water out of the lifters and bearings. You should be OK after that.
Ok, thanks for your help. I'll see what i can chase up. I might do a couple of oil changes and see if i can get that additive.
