sbiddle Posted April 28, 2005 Share Posted April 28, 2005 I find that sometimes the wipers arc is short, and sometimes the arc is so long that it slaps the window molding on the driver side and the bottom. Is there an adjustment for wiper travel? Thanks, Steve Link to comment Share on other sites More sharing options...
lmdew Posted April 28, 2005 Share Posted April 28, 2005 No adjustments, make sure the nut holding the wiper arm on is tight and the shaft splines are good. If both wipers are changing, look at the motor mounts. Link to comment Share on other sites More sharing options...
Strakes Posted April 28, 2005 Share Posted April 28, 2005 Our 93 used to do this. I took off the wiper arms and the plastic base windshield trim. I found that there was a ton of gunk caked on and in the moving mechanisms. I cleaned them out with WD40 and then lubed them with a lithium based spray grease. This did the trick and haven't had a problem for over a year now. Link to comment Share on other sites More sharing options...
