kidwired Posted April 28, 2005 Share Posted April 28, 2005 got a code 11- open and closed ends of drivers door latch switch are ON. hmmm yeah, that helps... soooo thats the switch in the latch. Do I just replace it? The seatbelt had been clicking, it's stopped... did I burn up the motor too? Is the switch replaceable or is a part of the door latch mechanism? Link to comment Share on other sites More sharing options...
kidwired Posted May 12, 2005 Author Share Posted May 12, 2005 I'm getting no where w/ this. Is the switch in the latch replaceable? or do I need an entire latch? Does anyone have a PN for the switch? What about the motor. I can't get it to run. is there a relay or something I can check? What -/+ to what wires should run it? theres a 2 wire connector I get - on the green and - on the blue, w/ door open and closed. Theres a 3 wire b/w open, y/r runs pass side seatbelt when I put positive to it. 2 blks both - And to replace the motor, do I need to remove the whole assembly including the cable? Link to comment Share on other sites More sharing options...
Gnuman Posted May 12, 2005 Share Posted May 12, 2005 I'm getting no where w/ this. Is the switch in the latch replaceable? or do I need an entire latch? Does anyone have a PN for the switch? What about the motor. I can't get it to run. is there a relay or something I can check? What -/+ to what wires should run it? theres a 2 wire connector I get - on the green and - on the blue, w/ door open and closed. Theres a 3 wire b/w open, y/r runs pass side seatbelt when I put positive to it. 2 blks both - And to replace the motor, do I need to remove the whole assembly including the cable? I can get you any and all of the parts to that assy. PM me for a phone # Link to comment Share on other sites More sharing options...
kidwired Posted May 12, 2005 Author Share Posted May 12, 2005 SANJAY!! Hey bro PM'd ya Link to comment Share on other sites More sharing options...
