help 1982 GL1800 hatch lifters
probably does as I think hydraulics did not come out until 1983/1984 - easiest way is to check in your owner's manual (if you have it) - if it specs an interval at which the valves should be adjusted it is solid
realize the engine may not be original too....
I don't have the owners manual. The engine is an EA81, automatic, 1800 serial# 751670, bin# JF1 AF43BX CC103748
