Tarrega Posted April 30, 2005 Share Posted April 30, 2005 Does my Subaru have solid lifters? Link to comment Share on other sites More sharing options...
85Sub4WD Posted April 30, 2005 Share Posted April 30, 2005 probably does as I think hydraulics did not come out until 1983/1984 - easiest way is to check in your owner's manual (if you have it) - if it specs an interval at which the valves should be adjusted it is solid realize the engine may not be original too.... Link to comment Share on other sites More sharing options...
Tarrega Posted May 1, 2005 Author Share Posted May 1, 2005 probably does as I think hydraulics did not come out until 1983/1984 - easiest way is to check in your owner's manual (if you have it) - if it specs an interval at which the valves should be adjusted it is solid realize the engine may not be original too.... I don't have the owners manual. The engine is an EA81, automatic, 1800 serial# 751670, bin# JF1 AF43BX CC103748 Link to comment Share on other sites More sharing options...
ShawnW Posted May 1, 2005 Share Posted May 1, 2005 Does it have a Sticker on the valve covers? Link to comment Share on other sites More sharing options...
