SuBrat84 Posted May 3, 2005 Share Posted May 3, 2005 So I decided to stop being lazy about getting this thing registered and licensed.. We took it to emissions today. ... It doesn't look good. (1984 Subaru GL BRAT ea81 Carbed all stock) Equipment Inspection Results: Air System : Pass Gas Cap Test: Pass Catalytic Converter: Pass Emissions Inspection Results: Hydrocarbons in PPM - Loaded: 232 / Standard 220 <--- FAIL Hydrocarbons in PPM - IDLE: 1341 / Standard 220 <--- FAIL!!!!!! Carbon Monoxide in % - Loaded: 0.06 / Standard 1.20 <--- PASS (phew) Carbon Monoxide in % - IDLE: 0.14 / Standard 1.20 <--- PASS! (yay!) Based on these results the emissions station informed me that have a MISFIRE on one of my cylinders! I now have 60 days where I can return for ONE free emissions test. So I brougth it home and I checked the timing and it was way off (like 14 or something absurd).. I got it as close to 8 degrees BTDC as I could and it seems to be running a lot better already. I plan to replace the dist. cap and rotor. Things I have done recently include the following: New Plugs New Plug Wires New Radiator + hoses New Air Filter, PCV Filter New PCV Valve. Oil Change w/ new filter / drain plug. New Oil Pan Gasket New Valve Cover Gaskets Added Manual Transaxle Fluid New Water Pump belt / Alternator belt. There maybe something else I did but I can't think of it right now.. Anyway here's my question: Can anyone think of anything else I should do to get my emissions working as good as possible? I'm really hopin that the timing issue was the problem.. but I want to do as much as possible so I dont have to end up paying another emissions fee. Oh yah.. I'm going to unplug my drivers side ASV as well to see if it's any quieter with the timing correct now. Thanks for reading my long rump roast emissions post and thanks in advance for any input you might have!! -Eli- Quote Link to comment Share on other sites More sharing options...
ShawnW Posted May 3, 2005 Share Posted May 3, 2005 I wouldnt be surprised if you have solved it already with the timing. Before testing, get it REALLY hot, so the heat is cranking so hot you cant stand it when it comes out and make sure your headlights and other accessories are off. What kind of MPG are you getting so far? Did you plug off the air suction valves in the past with a quarter, etc? Have seen that posted lately. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 3, 2005 Author Share Posted May 3, 2005 I don't know my MPG.. I haven't driven it that much.. Yeah I put a quarter in the drivers side hose just on the ASV side of the little black box.. it was really noisy before i did that.. but im thinking that it might actually have been the timing thing making all the noise! I'm going to take the quarter out tonight and see how it acts. Thanks! Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 4, 2005 Author Share Posted May 4, 2005 Took the quarter out.. sounds a lot better timed closer to 8 degrees BTDC.. need a better timing light. *Bump* Quote Link to comment Share on other sites More sharing options...
Ratty2Austin Posted May 5, 2005 Share Posted May 5, 2005 i actually need to take mine in now too.. especially after I reinstalled ALL the emissions hardware and hoses, AND a reman'ed carb!! (should make a difference right? ) sounds like you may have gotten yours a bunch closer! good luck! Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted June 1, 2005 Author Share Posted June 1, 2005 New plug wires, again.. (old ones were POS and BROKE!!!) ... New disty cap and rotor.. Good timing light 8 degrees +/- 2 degrees BTDC.. Idle at 900 +/- 100 rpms. Drove the brat ALL day w/ 91 Octance in her.. PASSED EMISSIONS!!!! Hydro carbons at load = 85 ... at Idle = 180 ... Standard = 220.. WOOT!! Carbon Monoxide at load = 0.4 and idle = 0.07 (WHOA!) .. Standard = 1.2! Yes!!! I'm soo happy the brat is going to be street legal!!!! Quote Link to comment Share on other sites More sharing options...
Camelwagon Posted August 25, 2005 Share Posted August 25, 2005 My 85 GL didnt pass either, high HC, 400, standard is 220. But passed CO, in fact the CO was very low, .04 and standard is 1.2. They say that my timing needs advanced a bit, does this sound correct? Sounds like its too lean too, thats what high HC means. Thanks. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted August 26, 2005 Author Share Posted August 26, 2005 Yeah.. I'm not sure if your timing needs to be advanced or retarded .. get a good light on there and get it right around what your specs say it should be.. 8 or 9 btdc .. probably shouldn't have to mess with your fuel mixture or anything. Quote Link to comment Share on other sites More sharing options...
Camelwagon Posted August 26, 2005 Share Posted August 26, 2005 Well seems like my carb needs rebuilt, had it checked and i'm not getting enough fuel in there, its running lean either way I turn the mixture screw, doesnt change much. Very weird. Not sure if he's right or wat but he showed me on his emissions computer, he turned the screw from all the way left to all the way right and the HC's were really high either way. And i tired couple bottles of HEET and denatured alcohol and that "Guaranteed to Pass" crap and Seafoam and nothing helped, still failed emissions. Quote Link to comment Share on other sites More sharing options...
