idosubaru Posted May 4, 2005 Share Posted May 4, 2005 i'm not super familiar with clutches. drove one of my XT6's that i never drive today. push the clutch pedal in and after a little bit of movement it gets really loose and goes to the floor. put it in gear and let the clutch pedal up and it catches really high. so it needs a new clutch and i have all the parts. my question is that when i used to drive manual trans XT6's (i drive all auto's now) the clutch would go out and start slipping. why does this one seem to grab crisp and not slip? what's the difference? Link to comment Share on other sites More sharing options...
erik litchy Posted May 4, 2005 Share Posted May 4, 2005 I had a 93 golf that was the same way. it never slipped so there was really no problem Link to comment Share on other sites More sharing options...
TomRhere Posted May 4, 2005 Share Posted May 4, 2005 I would try to adjust the cable 1st before I tackled a clutch job, just to be sure. Link to comment Share on other sites More sharing options...
idosubaru Posted May 4, 2005 Author Share Posted May 4, 2005 adjust what? where it catches, take up slack? i've pulled transmissions and replaced auto trans and motors...but not in manual trans so i'm not familiar with the clutch adjustment. though i have the FSM. fairly straight forward i assume? Link to comment Share on other sites More sharing options...
WJM Posted May 4, 2005 Share Posted May 4, 2005 its a matter of adjust the nuts on the end of the cable on the clutch arm on the transmission. Link to comment Share on other sites More sharing options...
idosubaru Posted May 4, 2005 Author Share Posted May 4, 2005 got it, i recall those nuts. thanks all Link to comment Share on other sites More sharing options...
