myfinalcoffinx Posted May 5, 2005 Share Posted May 5, 2005 I'm having a bit of trouble with my exhaust. It's an EA81. The gasket where the pipe bolts to the flange leaks quite a bit on both sides. I am curious as to where to get 2 new gaskets, their approproiate sizes (distance between bolts, diameter of the hole etc. or a part number) and what kind of sealer to use. I tried autozone but they gave me two round gaskets that were definately the wrong ones. Link to comment Share on other sites More sharing options...
BobBrumby Posted May 5, 2005 Share Posted May 5, 2005 try a subaru dealer and you dont need any sealent. Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 5, 2005 Share Posted May 5, 2005 I'm not sure which part of the pipe you need the gaskets for? As for the sealer you want to get "Ultra Copper" sensor safe high temp RTV Silicone Gasket Maker. I got mine from autozone.. 6 bux for a 3 ounce tube Link to comment Share on other sites More sharing options...
MorganM Posted May 5, 2005 Share Posted May 5, 2005 try a subaru dealer and you dont need any sealent. True, true... Link to comment Share on other sites More sharing options...
MilesFox Posted May 5, 2005 Share Posted May 5, 2005 do you mean the f;ange under the car after the tranny? you will want a DONUT GASKET about 2 in or so, and use spring bolts as replacements Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 5, 2005 Share Posted May 5, 2005 yeah if its that donut gasket you're talking about dont use any sealer. Link to comment Share on other sites More sharing options...
myfinalcoffinx Posted May 6, 2005 Author Share Posted May 6, 2005 All this said, I'm not quite sure I have my terminology right... I need to fix a leak coming from a lack of a gasket at the point where the exhaust y pipe bolts to the bottom of the engine. It says in my manual that it bolts directly to the flange. What do I need to ask for at the dealer? Link to comment Share on other sites More sharing options...
MilesFox Posted May 6, 2005 Share Posted May 6, 2005 ask for exhaust manifild/header gasket, tell them its the engine to exhaust side. i like to use the copper silicone as well on both sides of the gasket, use anti-seize compound on the nuts Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 6, 2005 Share Posted May 6, 2005 The only place I could find in Tucson that stocks those gaskets is Midas. Good luck! Link to comment Share on other sites More sharing options...
