Dante Posted May 5, 2005 Share Posted May 5, 2005 I've got a 3.9 LSD on my '83 GL wagon. I'm thinking of replacing the '83 wagon with the nicest EA82 GL wagon I can find. I'd like to keep the LSD and based on a quick search, it looks like it can be made to work. Is that correct? If so, any tricks to making the swap? Link to comment Share on other sites More sharing options...
erik litchy Posted May 5, 2005 Share Posted May 5, 2005 yes if its a non turbo one Link to comment Share on other sites More sharing options...
subyrally Posted May 5, 2005 Share Posted May 5, 2005 it will work as long as the tranny in the car its going into is also a 3.9. you just have to make sure the gearing matches on the final drive, otherwise, youll end up with drive line wind up, or binding. Link to comment Share on other sites More sharing options...
mcbrat Posted May 6, 2005 Share Posted May 6, 2005 should be a direct drop in...... as long as it matches the tranny Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 6, 2005 Share Posted May 6, 2005 Hope you dont mind if I jump in on this thread.. was wondering what LSD I would need to get LSD on an 84 brat?? And what cars I could try and get it off? Thanks! Link to comment Share on other sites More sharing options...
subynut Posted May 6, 2005 Share Posted May 6, 2005 Find a late 80's GL-10 turbo. That has the LSD in it. Just look under the rear end of the car and look for the LSD label. You just would hafto swap the LSD unit out of the 3.7 diff into the 3,9 open diff that's in your Brat. Here's a link to the USRM with a good writeup on how to do it: http://www.ultimatesubaru.org/forum/article.php?a=36 Link to comment Share on other sites More sharing options...
