TROGDOR! Posted May 5, 2005 Share Posted May 5, 2005 Going to tow one of my RX's to the shop this weekend, and tow the other back to my house. Question- do I need to unbolt the rear driveshaft, or will they be okay if I just leave them in neutral? They will be towed on a dolly, front wheels up, rear wheels down. Link to comment Share on other sites More sharing options...
subyrally Posted May 5, 2005 Share Posted May 5, 2005 i say that you should spring for a flatbed tow truck, just to be on the safe side. i trust not hte tow dolly on a 4wd, or awd car. good luck though. if its dual range 5 spd, it should be fine, but if its full time 4wd or awd, i wouldnt leave tires on the ground without disconnection the drive shaft, its too easy to have the car jump the dolly if there is power transfer from the wheels on the ground to the wheels in the dolly, even if in neutral. Link to comment Share on other sites More sharing options...
MysteriousXTC Posted May 5, 2005 Share Posted May 5, 2005 yeah if its a dual range etc.. just through it in nuetral and place the transfer case in FWD and ur good to go on a dolly... I was skepttical at first but i just bought one and had to tow it 20 miles and it worked no problem... Link to comment Share on other sites More sharing options...
TROGDOR! Posted May 5, 2005 Author Share Posted May 5, 2005 This one has no FWD setting. It is full time 4WD. Link to comment Share on other sites More sharing options...
subyrally Posted May 6, 2005 Share Posted May 6, 2005 i dont reccomend the tow dolly, its a good chance that it will end up in disaster. Link to comment Share on other sites More sharing options...
MSSLGECKO Posted May 6, 2005 Share Posted May 6, 2005 Just out of curiousity, what are the 'risks' involved. . . .why would it end in disaster [towing an AWD car]? Link to comment Share on other sites More sharing options...
calebz Posted May 6, 2005 Share Posted May 6, 2005 Just out of curiousity, what are the 'risks' involved. . . .why would it end in disaster [towing an AWD car]? Center diff doesn't take well to the abuse of 2 wheels turning and two being stationary. Link to comment Share on other sites More sharing options...
JWX Posted May 6, 2005 Share Posted May 6, 2005 how far do you have to tow them? and over what roads and such? Link to comment Share on other sites More sharing options...
NorthWet Posted May 6, 2005 Share Posted May 6, 2005 Just pull the rear driveshaft segment and you are good. It bolts to flanges on both ends, 12mm (maybe 13mm) wrenches needed. No worry about AWD, fluid leakage, driveshaft falling off, or whatever. Link to comment Share on other sites More sharing options...
john in KY Posted May 6, 2005 Share Posted May 6, 2005 I've towed 2 AWD XT6s with a dolley and with just the driveshafts removed probably a total of 500 miles. Had no problems whatsoever and still drive both cars. Won't hesitate to tow another cross country if needed. Link to comment Share on other sites More sharing options...
subyrally Posted May 6, 2005 Share Posted May 6, 2005 without pulling a drive shaft, if you tow an awd car on a dolly, not only can you hurt the center diff, but you also run the rsk of having the car jump the dolly and go outta control.even if the car is in neutral, the transmission is still linking both sets of wheels and can cause serious damage. thats why i always insist on a flat bed to move my cars if they have to be towed. Link to comment Share on other sites More sharing options...
75subie Posted May 6, 2005 Share Posted May 6, 2005 if you are renting the dolly from uhaul, just go for the extra $15-20 and rent a 16foot car trailer.they make them pretty easy to use, and alot safer for the rx.dollys do work good for 2wd or cars that are not full time 4wd.good luck Link to comment Share on other sites More sharing options...
Dr. RX Posted May 6, 2005 Share Posted May 6, 2005 Unless you trailer it, you will have to remove the driveline. With the driveline move, you can move it short distances (less then 100 feet) under it's own power by locking the center diff. Link to comment Share on other sites More sharing options...
TROGDOR! Posted May 6, 2005 Author Share Posted May 6, 2005 It is being towed for free by a buddy, so getting a car trailer would cost me quite a bit more. I'll just remove the driveshaft segment before towing it. No biggie. Just was wondering if it was necessary; I've never had a FT4WD car before. Link to comment Share on other sites More sharing options...
