Mr. Carb Posted May 7, 2005 Share Posted May 7, 2005 in my 84 brat, wich is the none ecu model, decided the stop lamp warning light was gonna come on, and stay on. None of the lights are burnt out, Where and what could cause this to suddenly happen randomly? (I was working on putting in a radio when it decided to do this) If anyone has any ideas, let me know, thanks. Link to comment Share on other sites More sharing options...
BobBrumby Posted May 7, 2005 Share Posted May 7, 2005 maybe you bumped the switch on the hand brake? Link to comment Share on other sites More sharing options...
Mykeys Toy Posted May 7, 2005 Share Posted May 7, 2005 Which place in the fuse box did you tap for acc. power.. it makes a difference. Mike Link to comment Share on other sites More sharing options...
Mr. Carb Posted May 7, 2005 Author Share Posted May 7, 2005 I never installed the radio, the acc power comes from the orginal acc power that was there for the orginal subaru radio, I have made no changes to my wireing harness at all. It's just decided it's going to stay on now, it sometimes, will turn off when I hit the breaks, and stay off until I release them again, sometimes... but most of the time it's just stuck on no matter what, and it's always On, when I'm not hitting the breaks. what I want to know is, where IS the module that kicks on that light, and what could cause it to fail like this... Link to comment Share on other sites More sharing options...
ShawnW Posted May 7, 2005 Share Posted May 7, 2005 Check your brake fluid level too. Link to comment Share on other sites More sharing options...
Mr. Carb Posted May 7, 2005 Author Share Posted May 7, 2005 lol, just toped off the brake fluid 2 days ago, cause the brake fluid light was on.... Link to comment Share on other sites More sharing options...
ruparts Posted May 8, 2005 Share Posted May 8, 2005 Take a look at the little switch that is activated by the brake pedal , its up at the top in the area near the shaft that the pedal is mounted on( brake and clutch pedal box assembly). may be shorted out, or out of adjustment . Mr. Carb said: lol, just toped off the brake fluid 2 days ago, cause the brake fluid light was on.... Link to comment Share on other sites More sharing options...
Mr. Carb Posted May 8, 2005 Author Share Posted May 8, 2005 yeah, I took alook at that guy too, the thing is, all my lights, and brake lights work. if that switch was bad, the brake lights wouldn't work. I'm thinking either the sensor is bad, or, it's being told the brake lights are on when they're really off, so it thinks they're out, because they're not on, I'm trying to figure out where the sensor is... Does anyone know where the sensor is? Link to comment Share on other sites More sharing options...
johnvlizr Posted June 25, 2012 Share Posted June 25, 2012 on a 88 dl wagon its located in the passenger side tail light compartment accessed by a removable panel. my lights are all ok but the "stop lamp" dash light stays on all the time-i think im just going to remove the bulb so i dont have to look at it:-most cars dont have one anyway. I imagine you could also figure out a way to just remove the sensor instead. Link to comment Share on other sites More sharing options...
Turbone Posted June 25, 2012 Share Posted June 25, 2012 I bet he figured out the problem too.......7yrs ago! Link to comment Share on other sites More sharing options...
johnvlizr Posted June 26, 2012 Share Posted June 26, 2012 i thought someone else with a similar situation might search and read the post. i get lots of info here for my 88 dl from old posts. problem? Link to comment Share on other sites More sharing options...
