Meeky Moose Posted May 7, 2005 Share Posted May 7, 2005 was only about 1/4 mile from my house though, lol.. started coughing, sputtering, then it would die.. would start back up, run for about 5 feet and die.. then it finally just wouldn't start at all.. so i changed the fuel filter (2nd time in 2 tanks of gas) still no go. so i swapped out the fuel pump. still no go.. bad part was, you could crank it and if you pumped the hell outa it it would try to start.. so i was thin king fuel related.. but i was gettin plenty of fuel.. then i swapped out the MSD blaster coil with a stock one.. fired right up, and carried my happy arse home.. this is the first subie i have ever had that left me on the side of the road like that.. was a little dissapointed. lol.. Link to comment Share on other sites More sharing options...
carfreak85 Posted May 7, 2005 Share Posted May 7, 2005 I'm sorry to hear that! Especially since you had a MSD and not an Accel go bad. I carry a stock coil in my tool box for the day this happens to me. Link to comment Share on other sites More sharing options...
subie94 Posted May 7, 2005 Share Posted May 7, 2005 i feel your pain,my old 92 legacy did the same.it was partly,mostly my fault though.several weeks before i had changed out the plugs for a set of bosch plat plus four.i guess during install,i crossed the threads on one of the plugs. while going to a friends house one day all of a sudden it started to sputter along with this weird noise from the engine.i managed to pull off onto a side road.opened up the hood to take a look an it turned out that i blew out a plug.turns out it was the one that i crossed.needless to say i had to have her towed home cause she didn't want to run very good with 3 plugs in.had the plug hole fixed with a heli-coil kit.course it took a couple days cause one-i never had to do it an two-had to wait for a guy from the dealership to come by(a friend of a friend of mine that works at a subie dealer) Link to comment Share on other sites More sharing options...
RavenTBK Posted May 8, 2005 Share Posted May 8, 2005 Which type Blaster is it? Well, was it? Link to comment Share on other sites More sharing options...
