Mr Burns Posted May 8, 2005 Share Posted May 8, 2005 Hi... Just bought a 2005 Impreza RS Wagon... Just wondering if anybody has bought or made a grille of some sort to protect the radiator from stones or bugs? It seems awfully exposed...? Link to comment Share on other sites More sharing options...
frag Posted May 8, 2005 Share Posted May 8, 2005 I second your question (or request). I've got a new rad waiting for install cause the old one (10 years) has its lower part blocked by bugs and by bent fins (small rocks). Not showing any sign of overheating yet (save the fact that the fan kicks in a little sooner now when I'm stopped and engine is idling) but I prefer an ounce of prevention... I was thinking of installing a piece of door screen behind the bumper's openings to protect the new one, but have not yet devised any precise method of installation. Any other ideas? Link to comment Share on other sites More sharing options...
Subie Gal Posted May 10, 2005 Share Posted May 10, 2005 aluminum grills will bend and rust mesh is too flimsy i bought grillcraft www.grillcraft.com steel powdercoated - wont chip, wont rust air gets through but not much else does! black or silver easy install see: http://www.grillcraft.com/applications/applications.asp?action=viewDetails&make=SUBARU&model=SUBARU+IMPREZA&ext=WRX%2C+STI%2C+RS+%28MODELS%29&years=2004%2D2005 Jamie Link to comment Share on other sites More sharing options...
Mr Burns Posted May 10, 2005 Author Share Posted May 10, 2005 Cool... Thanks for the tip. It makes your car as smile as much as I do when I drive... Link to comment Share on other sites More sharing options...
frag Posted May 10, 2005 Share Posted May 10, 2005 aluminum grills will bend and rustmesh is too flimsy i bought grillcraft www.grillcraft.com steel powdercoated - wont chip, wont rust air gets through but not much else does! black or silver easy install see: http://www.grillcraft.com/applications/applications.asp?action=viewDetails&make=SUBARU&model=SUBARU+IMPREZA&ext=WRX%2C+STI%2C+RS+%28MODELS%29&years=2004%2D2005 Jamie Nice indeed! But nothing for my Legacy. Any DIYer has any idea? Link to comment Share on other sites More sharing options...
blitz Posted May 10, 2005 Share Posted May 10, 2005 I fabbed and installed one on the lower section of my Impreza. I just wish that I'd've done it before all the evaporator fins got bent shut. Link to comment Share on other sites More sharing options...
frag Posted May 10, 2005 Share Posted May 10, 2005 I fabbed and installed one on the lower section of my Impreza. I just wish that I'd've done it before all the evaporator fins got bent shut. Some details would be appreciated. TIA. Link to comment Share on other sites More sharing options...
blitz Posted May 10, 2005 Share Posted May 10, 2005 Some details would be appreciated.TIA. It was pretty straightforward really. I used a piece of expanded aluminum that I had laying around (expanded metal has the diamond-shaped openings formed by first slitting, then stretching the piece). The stuff I used had holes that were small enough to keep out insects, rocks, or other potentially damaging detritus, but large enough to maintain adequate air flow. It may also have had a clear anodization on account of salt having not affected it. I cut it to shape, then fastened it with some nuts & bolts that I passed through holes I drilled in the lower facia below the bumper. It looks really similar to Subie Gal's photo except I did only the lower section, and I mounted mine behind the plastic body work rather than in front of it. Functionally it won't matter either way, it'll just look different. Any bug-screen will restrict air-flow to some degree, but I 'spose it's better to restrict flow by 10% with a guard than by 25% (or worse) from long-term damage and dried bugs. Most of the damage occurs when driving high-speed in the wee hours of the morning and those big friggin' bugs hit so hard you feel 'em vibrate the car. Home-improvment places have sections of expanded aluminum and enameled steel. Link to comment Share on other sites More sharing options...
