Meeky Moose Posted May 10, 2005 Share Posted May 10, 2005 this is the 85' gl lifted wagon i got a couple weeks ago, after an engine swap, and alot of TLC she came out pretty good. had to Dupont no.7 the hole car, then wax it.. turned that old oxidized paint job into a new one.. Link to comment Share on other sites More sharing options...
RainbowRoo Posted May 10, 2005 Share Posted May 10, 2005 She, is SWEET looking. Link to comment Share on other sites More sharing options...
MorganM Posted May 10, 2005 Share Posted May 10, 2005 Looks good !_! So what tires are going on it ?_? Link to comment Share on other sites More sharing options...
Meeky Moose Posted May 10, 2005 Author Share Posted May 10, 2005 well the ones on it now are a 195/65/14 need to go up to a 75 series to fill it in better i think. i don't wanna go to big cause it'll loose too much power.. as she sits now she'll run 100mph down the road at close to 5k rpms for about 20 miles and not even move the temp gauge, heh, just hums along.. i found this out when i had to take my manager to the ER the other night, lol.. also caught a foot of air when i took the offramp, that was fun Link to comment Share on other sites More sharing options...
A DOG Posted May 10, 2005 Share Posted May 10, 2005 Cool Beans! some mudin tires would make it look quite proper. Link to comment Share on other sites More sharing options...
soobmater Posted May 10, 2005 Share Posted May 10, 2005 It looks good. Link to comment Share on other sites More sharing options...
JWX Posted May 10, 2005 Share Posted May 10, 2005 that thing looks awesome Link to comment Share on other sites More sharing options...
XSNRG Posted May 11, 2005 Share Posted May 11, 2005 looks good...what's dupont no 7? Link to comment Share on other sites More sharing options...
gravelRX Posted May 11, 2005 Share Posted May 11, 2005 I'll give you 120.00 for the tires that are on it now(5) and come pick them up. Need to get that ratchet strap back too. Stay on top of the paint with wax or she'll go back to being dull. Does look good though. Jay Link to comment Share on other sites More sharing options...
sparkster58 Posted May 11, 2005 Share Posted May 11, 2005 Meeky.... give me the lowdown on your roof -rack...are the feet* bolted or wedged to the gutters??? spark Link to comment Share on other sites More sharing options...
gravelRX Posted May 11, 2005 Share Posted May 11, 2005 I can field this one.The roof rack is actually bolted to the factory roof rails and the weight is taken by the gutters. I didn't get to build the gutter clamps before I let the car go. looks like MM has some fabricating to do to finish up the rack right. Don't get me wrong, it works like a charm as is, just makes a bit of a racket inside the car. I've only seen the car this clean twice. It started it's life like this: Note bale of hay in the back. I have around 100 pictures of the resurrection and build-up if you would like them. MM, Did you use the clutch that was on the back of the spare engine? I was told that it was fairly fresh and the timing belts too. The car the engine came out of was run over(no kidding) by a dump truck. Compression was ~100 for all the cylinders. Glad to hear it's strong. I have the trim for the sides if you don't want to scavenge off the brown one. All the systems checked out OK on the Dolphin with exception of the heat furnace. I've got to diagnose that one soon. Did you have it going with full burner on and not just the pilot? Regards, Jay Link to comment Share on other sites More sharing options...
82bratavenger Posted May 11, 2005 Share Posted May 11, 2005 I think it looks great as well. I too am curious though what is Dupont no.7? Is it a cleaning chemical or a scratch pad or something else? I would like to get my Brat back to that High Pro Glow again Link to comment Share on other sites More sharing options...
subynut Posted May 11, 2005 Share Posted May 11, 2005 Looks nice! Good job! Link to comment Share on other sites More sharing options...
Meeky Moose Posted May 12, 2005 Author Share Posted May 12, 2005 well dupont no.7 is a metal cleaning compound, its not sold in walmart, or your big chain stores.. you can find it in grocery stores only. food lion, safeway, and a few others.. maybe albertsons for you west coasters.. in a green and white metal tub.. has kerosene in it, so it cleans everything up real nice.. then the wax just finishes it off.. Jay: look at the pics again already put the trim back on nieghbor had some wicked glue just for that, lol 15 min and it was a permanent bond. i'll pm you about the motorhome. ohh i used the clutch on the spare engine, before it wnt in, i pulled it off and checked it, the pressure plate still had the circular grooves in it from when it was made.. clutch disc was thicker than the other one also.. they were made a little different in design but it works as it should. also figured out the roof "booming" i need to put the center rails back on for the factory roof rack, theres no support there without them, i can duplicate the same "booming" just by cranking my stereo up, with the rack off it.. so tis not the rack.. Link to comment Share on other sites More sharing options...
gravelRX Posted May 24, 2005 Share Posted May 24, 2005 Did you notice all the Turbo wagon bit along the bottom of the wagon? You get that yet? How's she go? Jay Link to comment Share on other sites More sharing options...
gotime242 Posted May 24, 2005 Share Posted May 24, 2005 Looks awsome! Im totally diggin that roof rack Link to comment Share on other sites More sharing options...
GoldDiggerRoo Posted May 24, 2005 Share Posted May 24, 2005 Looks like I now know where the motorhome went huh! Link to comment Share on other sites More sharing options...
