EVO 8 injectors
Im bored. EVO 8 USDM injectors. 565 CCs. On the RX.
Tomorrow I should know if they work or not with the Intake and all that....they look like they will work, same connectors and they are topfeed...
I test fitted a set of 450cc Mitsu injectors a while back. They fit pretty well.
What do you mean by 'pretty well'? Do you mean it was a direct bolt on affair or did you have to tweak/modify it to meake it fit? If you had to modify it/them, what did you have to do to make them fit? Thanks!
WJM,
Did they fit?
