WJM Posted May 13, 2005 Share Posted May 13, 2005 Im bored. EVO 8 USDM injectors. 565 CCs. On the RX. Tomorrow I should know if they work or not with the Intake and all that....they look like they will work, same connectors and they are topfeed... Link to comment Share on other sites More sharing options...
subyrally Posted May 13, 2005 Share Posted May 13, 2005 dont see why not, give it a try will, id like to see what happens. how hard will it be to come up with a new fuel rail for em? Link to comment Share on other sites More sharing options...
GLCraig Posted May 13, 2005 Share Posted May 13, 2005 check to see if those injectors have roughly the same impedence as the stock ones. There's no need to fry your ECU as part of the R&D. Link to comment Share on other sites More sharing options...
Myxalplyx Posted May 13, 2005 Share Posted May 13, 2005 Tomorrow? Damn it, you should know by NOW. I hate suspense! Link to comment Share on other sites More sharing options...
nkx Posted May 13, 2005 Share Posted May 13, 2005 now you really have been succumbed by the dark side :-p Link to comment Share on other sites More sharing options...
WJM Posted May 13, 2005 Author Share Posted May 13, 2005 hey, they look like they will fit....so back off....you guys talk about using Nissan-Datsun injectors. :-p Link to comment Share on other sites More sharing options...
calebz Posted May 13, 2005 Share Posted May 13, 2005 I test fitted a set of 450cc Mitsu injectors a while back. They fit pretty well. Link to comment Share on other sites More sharing options...
garner Posted May 13, 2005 Share Posted May 13, 2005 hey, they look like they will fit....so back off....you guys talk about using Nissan-Datsun injectors. :-p atleast Nissan-Datsun is Fuji..... :-p garner Link to comment Share on other sites More sharing options...
Myxalplyx Posted May 13, 2005 Share Posted May 13, 2005 I test fitted a set of 450cc Mitsu injectors a while back. They fit pretty well. What do you mean by 'pretty well'? Do you mean it was a direct bolt on affair or did you have to tweak/modify it to meake it fit? If you had to modify it/them, what did you have to do to make them fit? Thanks! WJM, Did they fit? Link to comment Share on other sites More sharing options...
Subarutex Posted May 13, 2005 Share Posted May 13, 2005 I test fitted a set of 450cc Mitsu injectors a while back. They fit pretty well. Hush Caleb! Back to your box. **MOVE ALONG FOLKS.... NOTHING TO SEE HERE** Link to comment Share on other sites More sharing options...
WJM Posted May 14, 2005 Author Share Posted May 14, 2005 Too late. Its out there. I did not get a chance to test the EVO 8 injectors yet. I was busy making the car drivable again. Link to comment Share on other sites More sharing options...
