floortom Posted May 15, 2005 Share Posted May 15, 2005 thanks for trying, my daily driver has a cracks between the valves! I need the old fart to be awake before monday. will come and pay cash! no wrecking yards open on sunday. im located in north portland...will pay if you can drop off. thanks, ken @ 503.735.1583 poor old brat. Link to comment Share on other sites More sharing options...
Alex C Posted May 15, 2005 Share Posted May 15, 2005 Hate to say it, but they all have cracks between the valves. If you pressure checked it they should check fine. They are OEM cracks. Mine has had cracks forever, as long as its not all the way through(which happens very rarely) it is fine. What caused you to take the heads off? Alex Link to comment Share on other sites More sharing options...
floortom Posted May 15, 2005 Author Share Posted May 15, 2005 steam from the exhaust and a milkshake in the crankcase, loss of water. pulled nearly 2 gal. from plug. 2 wet plugs on rt. side. Link to comment Share on other sites More sharing options...
floortom Posted May 15, 2005 Author Share Posted May 15, 2005 also the cracks were large enough to put your thumbnail though. wish i had pics. Link to comment Share on other sites More sharing options...
Alex C Posted May 15, 2005 Share Posted May 15, 2005 for reference the cracks between all of my valves you could fit a fingernail in. I would suspect you either blew out a freeze plug, or just blew the headgaskets, which is pretty normal to do. I would trust the heads with the cracks. If you still have doubts, take some pictures and post them. Alex Link to comment Share on other sites More sharing options...
floortom Posted May 15, 2005 Author Share Posted May 15, 2005 pic on this bat channel......stay tuned. Link to comment Share on other sites More sharing options...
GLCraig Posted May 15, 2005 Share Posted May 15, 2005 Why didn't you call Mt. Tech? They're open on Saturday. Link to comment Share on other sites More sharing options...
MilesFox Posted May 15, 2005 Share Posted May 15, 2005 yeah you had a blown head gasket the milkshake was not related to the cracks, pull any good head or the one off the other side of the motor and they will be there if they make you uncomfprtable smoosh the crack down with a drift. its all metal and no water passage, the very worst that can happen is a valve seat will fall out in severe cases for example, my buddy had this rx ea82 gen II turbo heads, pulled them off cause of a rod knock. cracks between the valves. cracks all the way down to the valve guides. port and polish and carb compression block and road trips and 10k mile later no problems Link to comment Share on other sites More sharing options...
