TahoeFerrari Posted May 18, 2005 Share Posted May 18, 2005 According to engine specs on pp 3-4 TO 3-9 of "Chilton 1985-96 Repair Manual" (#64302) for '87 to '89 1.8L SPFI engines, 2WD has 84 hp @ 5200 rpm and 101 ftlb torque @ 3200 while 4WD has 90 hp @ 5200 rpm and 101 ftlb torque @ 2800 Bore, stroke, valve diam., cam lift, etc. all appear to be the same, so what is the difference in these engines?? 1) Is cam profile different? 2) Is control module programmed differently? 3) Something in distributor (I know there's no vacuum advance, how 'bout centrifugal adv. or something else?) 4) Something else? (Beginning with '90 when all 1.8L SPFIs were AWD, power and torque are shown as 90 hp @ 5200 and 101 ftlb torque @ 2800 - same as pre '90 4WDs). Reason I'm asking is that I just installed an engine + disty + complete TBInjection from a 2WD '87 4 dr 5 spd in my '87 4WD 3 door d/r 5 spd and it seems to be somewhat stronger over 3000 rpm than it ever did with the original engine + disty + TBI - kind of confirming that the peak torque is being developed at higher rpms. (I know, I know. Someone is probably going to tell me that the only diff is the ECU - which is still the orig. 4WD unit - and thus my stronger performance is all imaginary!!) Link to comment Share on other sites More sharing options...
WJM Posted May 18, 2005 Share Posted May 18, 2005 A lot fo 3rd party books and manuals have info screwed up. I would only go by owner's manuals and factory (from SUBARU only) information for this stuff. To my knowledge...SPFI across all years, regardless of 5spd/auto/2wd/4wd or any combination of those are all the same HP/TQ per RPM...and its somewhere between 85HP and 92HP...no idea on TQ...but that 101 fig sounds about right. I know MPFI is 97hp and something like 105~110 tq...Turbo is 111hp@5200 for 85~86, 115hp@5500 for 87+ and both have 136 tq at 2800 rpm. Mine.. ..234hp@5000 and 312tq@3500. Link to comment Share on other sites More sharing options...
TahoeFerrari Posted May 18, 2005 Author Share Posted May 18, 2005 I always thought they were all the same as well. I always suspect 3rd party manuals, so I also just downloaded PDF of '89 FSM and it shows similar (but conflicting) info (pp 4-5 of sect 1-1) for 4 door spfi sedan: 2WD is 84 hp @ 5200 and 101 ftlb @ 2800 4WD is 90 hp @ 5200 and 101 ftlb @ 2800 but shows 90/5200 & 101/2800 for 2WD and 4WD spfi wagons on pp 10-11 of same section and shows 90/5200 & 101/2800 for 2WD and 4WD spfi 3-doors on p 15. Maybe that's why info in Chilton is wrong - it sounds like maybe '89 FSM is wrong for the 4 door 2WD as well. Thanks for your reply. Link to comment Share on other sites More sharing options...
