yorab Posted May 19, 2005 Share Posted May 19, 2005 My heater blower has been acting kinda strange since last winter. I've finally gotten a chance to do some work on it. Here's the lowdown: if the engine is cold, the blower will COME ON and STAY ON indefinitely as long as I don't turn off the ignition. Works fine at all blower speeds. If, for instance, I stop by a gas station and turn the ignition off with the engine warmed up, the blower will not come on after I restart the car. I have tried to jump voltage to the blower while the engine is warm and the blower will run fine. I removed the resistor pack but I don't know how to test them. My resistor pack consists of three open coils, not the glass tube kind that I have read about in other posts. Any ideas? Link to comment Share on other sites More sharing options...
Cougar Posted May 19, 2005 Share Posted May 19, 2005 Since the speed are working ok then resistors are good. Just make sure there are no faulty connections. There is a blower relay in the dash near the radio area. It may be the first of four relays. You could try tapping it while the problem is occuring or swap it with another one if it fits correctly. Link to comment Share on other sites More sharing options...
yorab Posted May 19, 2005 Author Share Posted May 19, 2005 By the way, it's a 1986 GL manual 4wd. Link to comment Share on other sites More sharing options...
yorab Posted May 19, 2005 Author Share Posted May 19, 2005 Before I had a chance to check the relay, I bumped the resistor pack coils and one broke. They are very brittle. Does anybody know where to find another pack? Link to comment Share on other sites More sharing options...
moosens Posted May 19, 2005 Share Posted May 19, 2005 A little tin foil works too.As long as current flows through it with they'll work,regardless of the amount of that ceramic goop. As for the relays,I believe you need to find the one with the larger diameter (heavier guage) blue wires going to it.I don't have my manuals handy so someone correct me if I'm wrong. I've had relays go,motors,resistor packs and I've always been able to get them going again with minimal trouble. Link to comment Share on other sites More sharing options...
yorab Posted May 20, 2005 Author Share Posted May 20, 2005 I may try to solder the coil back together, but I think the solder won't stick to the brittle coils. They broke in a couple of places. Where exactly do I find these relays for the blower? Link to comment Share on other sites More sharing options...
Cougar Posted May 20, 2005 Share Posted May 20, 2005 You really can't repair these. It is best to just get a new set from a dealer. The relay should be near the radio area and may be the first of four as I mentioned in my first post. Link to comment Share on other sites More sharing options...
yorab Posted May 21, 2005 Author Share Posted May 21, 2005 the local Autozone had a resistor pack for 41 bucks. It's on order. How exactly does one go about testing a relay to determine if it is ok? I'll try to get back when I get the resistor in and the relays checked. Link to comment Share on other sites More sharing options...
yorab Posted May 22, 2005 Author Share Posted May 22, 2005 I found the relay under the steering column behind the dash. It was sticking. Had to tap it with a screwdriver to get it to work. Link to comment Share on other sites More sharing options...
Cougar Posted May 22, 2005 Share Posted May 22, 2005 Glad you found it and got it to go. You may have to end up replacing it later. The screwdriver tap trick is one of my favorites. Link to comment Share on other sites More sharing options...
yorab Posted May 23, 2005 Author Share Posted May 23, 2005 I went online and ordered two new relays. From what I gather (I could be wrong), the four relays in that aree are the same 12v 22A relays. If any of the others go bad I will have a spare. I found that my '86 EA82 uses the same part number relay as the earlier EA81 models (both 12v 22A), but the EA81 relays cost 10 bucks while the EA82 relays cost 15 bucks. Both have the same shape so they will tuck away under the dash nicely. I bought the cheaper relays figuring that as long as the specs are the same and the part numbers are the same, both will work. Link to comment Share on other sites More sharing options...
newsance Posted November 6, 2005 Share Posted November 6, 2005 I have the exact same problem. Heater fan works for the first few minutes of operation, then if you turn the car off, no fan. I also happen to have an 86. Mind telling me where exactly the relay is? I would like to limit what I have to take apart to find it. Also, any chance the relay is a autozone/pepboys/checker/etc part? Link to comment Share on other sites More sharing options...
Left_coast*9 Posted December 19, 2005 Share Posted December 19, 2005 That makes THREE OF US! ""Heater fan works for the first few minutes of operation, then if you turn the car off, no fan"" Please help, are there any write-ups, stickies, or web links to help find the relay, or facilitate the job? I have the exact same problem. Heater fan works for the first few minutes of operation, then if you turn the car off, no fan. I also happen to have an 86. Mind telling me where exactly the relay is? I would like to limit what I have to take apart to find it. Also, any chance the relay is a autozone/pepboys/checker/etc part? Link to comment Share on other sites More sharing options...
Sister7 Posted December 19, 2005 Share Posted December 19, 2005 My '86 used to do that too. I could get mine back on by giving it a good thump under the glovebox (where the blower motor is). It was a fun trick, especially when you ask your passenger to kick the car, but it didn't last too long. I ended up with a new (a la junkyard) blower motor and a new relay. Check for voltage at the blower motor. Mine had a bad relay thus no voltage. It also had eaten the brushes in the blower motor. The relays are in a little bracket behind the frontside of the dash just under the steering wheel. You'll need to remove the panel under the steering wheel and unscrew the fuse box to reach it. It's hard to see, but you can feel the relays. They are about 1" in diameter and semi-cylindrical. The ones with the black wires coming out are for your headlights. If you headlights work, borrow one to check the one for the blower motor. Link to comment Share on other sites More sharing options...
newsance Posted December 20, 2005 Share Posted December 20, 2005 That makes THREE OF US! ""Heater fan works for the first few minutes of operation, then if you turn the car off, no fan""Please help, are there any write-ups, stickies, or web links to help find the relay, or facilitate the job? I figured it out. It is under the kick panel immediately under the steering wheel/fuse area. You should take the screws off to lower the entire panel. It is up near the steering area. You will see several cylindrical relays up there, held in with spring clips. It is one of those. I just started swapping relays (they are all the same part)until my heater fan kicked on, and replaced the one that was in there. No more heater issues Link to comment Share on other sites More sharing options...
Left_coast*9 Posted December 31, 2005 Share Posted December 31, 2005 Thanks Newsance, I will be giving this a try. Add it to the list...altho this one will creep up in priority! Where did you get the correct relay? Subaru stealer? Blake I figured it out. It is under the kick panel immediately under the steering wheel/fuse area. You should take the screws off to lower the entire panel. It is up near the steering area. You will see several cylindrical relays up there, held in with spring clips. It is one of those. I just started swapping relays (they are all the same part)until my heater fan kicked on, and replaced the one that was in there. No more heater issues Link to comment Share on other sites More sharing options...
newsance Posted December 31, 2005 Share Posted December 31, 2005 I got one at my local checker, although they had to go to a catalog to find it. The systems didn't give them a part listing. Still, once they idenitifed it, they had it in stock. Link to comment Share on other sites More sharing options...
Left_coast*9 Posted January 2, 2006 Share Posted January 2, 2006 Ok, thanks -- I guess I'll try the local Sucks, Autozone or Napa. Thanks for the reply and tips. Blake I got one at my local checker, although they had to go to a catalog to find it. The systems didn't give them a part listing. Still, once they idenitifed it, they had it in stock. Link to comment Share on other sites More sharing options...
