mcbrat Posted May 20, 2005 Share Posted May 20, 2005 What gear oil do you need use in VLSD from Turbo Legacy? Link to comment Share on other sites More sharing options...
All_talk Posted May 20, 2005 Share Posted May 20, 2005 I'm pretty sure the VLSD unit is sealed, so regular gear oil should be fine. Gary Link to comment Share on other sites More sharing options...
blackbart Posted May 20, 2005 Share Posted May 20, 2005 I'm pretty sure the VLSD unit is sealed, so regular gear oil should be fine. Gary I second that. Link to comment Share on other sites More sharing options...
Dr. RX Posted May 20, 2005 Share Posted May 20, 2005 It's been awhile since I looked at the decal on mine, but doesn't it tell you what type of oil to use. I used LSD oil in mine, it worked fine. They are correct, the unit itself is sealed, there is no contact between the viscous fluid in the unit and the oil in the case. Link to comment Share on other sites More sharing options...
Setright Posted May 21, 2005 Share Posted May 21, 2005 Agreed. The center LSD is sealed. A rear LSD might need a particular oil. I would suggest using an API-GL5, 75W-85 oil the manual gearbox. Or a straight 80W. 90W gives slower shifts. Link to comment Share on other sites More sharing options...
DerFahrer Posted May 21, 2005 Share Posted May 21, 2005 Setright, they are meaning the rear LSD, which has the same principle. Any LSD Subaru has ever produced, which is the rear LSD's in cars like the 91 turbo Legacy, the newer Legacy GT's and such, and also ALL AWD center diffs, are all VLSD's and the LSD part is a sealed unit apart from the regular oil. Link to comment Share on other sites More sharing options...
blackbart Posted May 21, 2005 Share Posted May 21, 2005 If we are talking about rear Viscous LSD's (VLSD), like the 91 Tuurbo, it takes regular gear oil. The internal LSD parts are sealed, the oil will not get to it. If we are talking about the older LSD's (non-viscous, not VLSD) like the ones in the older RX's, they take special LSD fluid. Link to comment Share on other sites More sharing options...
NoahDL88 Posted May 22, 2005 Share Posted May 22, 2005 Setright, they are meaning the rear LSD, which has the same principle. Any LSD Subaru has ever produced, which is the rear LSD's in cars like the 91 turbo Legacy, the newer Legacy GT's and such, and also ALL AWD center diffs, are all VLSD's and the LSD part is a sealed unit apart from the regular oil. Not true, the pre 1990 LSD's were clutch type. Link to comment Share on other sites More sharing options...
