mcbrat Posted May 20, 2005 Share Posted May 20, 2005 What gear oil do you need use in VLSD from Turbo Legacy? Link to comment Share on other sites More sharing options...
All_talk Posted May 20, 2005 Share Posted May 20, 2005 I'm pretty sure the VLSD unit is sealed, so regular gear oil should be fine. Gary Link to comment Share on other sites More sharing options...
blackbart Posted May 20, 2005 Share Posted May 20, 2005 I'm pretty sure the VLSD unit is sealed, so regular gear oil should be fine. Gary I second that. Link to comment Share on other sites More sharing options...
Dr. RX Posted May 20, 2005 Share Posted May 20, 2005 It's been awhile since I looked at the decal on mine, but doesn't it tell you what type of oil to use. I used LSD oil in mine, it worked fine. They are correct, the unit itself is sealed, there is no contact between the viscous fluid in the unit and the oil in the case. Link to comment Share on other sites More sharing options...
