05blusub Posted May 21, 2005 Share Posted May 21, 2005 turn the #@$^ thing off. I suppose if you own a new Subaru you are only to have money in your pockets, not such things as nuts and bolts and other small items. Thee small items end up touching the panic button and .. there goes the alarm. The manual has no refrence on how to turn it off, the salesman know how to take my money but not much else, anyone know how to TURN IT OFF? (yes, perhaps black electricians tape would work, but I would like the real fix) Eric Link to comment Share on other sites More sharing options...
subie94 Posted May 21, 2005 Share Posted May 21, 2005 sometimes putting the key in the ignition and turning it to acc or on.on some just putting key in driversside door lock an turning it does the trick to. on the 99 avenger i had,i accidently hit the panic instead of unlock button and i shut it off by pushing panic button again. hope this helps are you asking how to prevent it from happening again(black electrical tape part)? simple don't put keys in pocket,clip them to your belt loop like i do. Link to comment Share on other sites More sharing options...
05blusub Posted May 22, 2005 Author Share Posted May 22, 2005 thanks for the reply. I don't wear belts, use pockets, and yes, I want to stop the panic button on the fob from working forever. Link to comment Share on other sites More sharing options...
Gnuman Posted May 22, 2005 Share Posted May 22, 2005 thanks for the reply. I don't wear belts, use pockets, and yes, I want to stop the panic button on the fob from working forever. Check your owner's manual. I think there is a procedure in there for disabling this feature. Or perhaps I'm confusing this with something else. . . Link to comment Share on other sites More sharing options...
05blusub Posted May 22, 2005 Author Share Posted May 22, 2005 there is a sequence in the manual on how to dissable the alarm on the car, not on how to turn off the panic button. The service dept. is out to lunch on this also. Is it possible that Subaru overlooked the possibility that some of us do not want a panic button? Link to comment Share on other sites More sharing options...
stevetone Posted May 22, 2005 Share Posted May 22, 2005 Maybe this is too obvious, but could you just use a key (gasp!) to lock and unlock your doors, and leave the fob at home? Link to comment Share on other sites More sharing options...
O5'Forester Posted May 22, 2005 Share Posted May 22, 2005 I had the same problem when i got my forester in Jan. I called Subaru to tell what was happining they said this is the first time they ever heard of this problem. the buttons on the fob are to shallow. i kept hitting the buttons when the keys where in my pocket. i solved this by adding a lenth of chain between the keyring and the remote fob. Link to comment Share on other sites More sharing options...
mattocs Posted May 22, 2005 Share Posted May 22, 2005 The keyless entry on my 96 OBW has the same problem...you unlock the car when the keys are in your pocket. I might try and disable keyless entry and unlock it by hand... Link to comment Share on other sites More sharing options...
schspeedster Posted May 22, 2005 Share Posted May 22, 2005 Find a carrying case. Link to comment Share on other sites More sharing options...
subie94 Posted May 22, 2005 Share Posted May 22, 2005 you could try opening the key fob and see if you could someway remove that pesky panic button. no button to hit the switch on the comp board inside fob,no panic alarm going off. Link to comment Share on other sites More sharing options...
Gnuman Posted May 22, 2005 Share Posted May 22, 2005 you could try opening the key fob and see if you could someway remove that pesky panic button. no button to hit the switch on the comp board inside fob,no panic alarm going off. That only exposes the actual button (A micro-switch) underneath to whatever would have hit the plastic button top. OK, my best shot missed the mark, as I was thinking that if you disable the alarm system, you disable everything. I guess not. . . Only thing left is the low-tech colution, of leaving the fob behind. . . Link to comment Share on other sites More sharing options...
