thedoctor Posted May 23, 2005 Share Posted May 23, 2005 A friend was following me home and told me my left rear wheel seemed to be angled in. I looked at the tread on that tire and the outside edge is wearing much more than the rest of the tire. What could be the cause of this and how do I fix it? Link to comment Share on other sites More sharing options...
moosens Posted May 23, 2005 Share Posted May 23, 2005 A friend was following me home and told me my left rear wheel seemed to be angled in. I looked at the tread on that tire and the outside edge is wearing much more than the rest of the tire. What could be the cause of this and how do I fix it? Get underneath and look good at the trailing arm that holds the wheel/spindle.Especially where it bolts up,but I've also had the arm just rot out through the box section so bad it nearly folded the wheel.I didn't care as much back then so I kept letting it go.Luckily I made it home and had it swapped out soon after. Or if it's a slight lean it could just be worn wheel bearings.See if the wheel has any play in it. Link to comment Share on other sites More sharing options...
scrapdaddytatum Posted May 23, 2005 Share Posted May 23, 2005 i second all that...... Link to comment Share on other sites More sharing options...
wintersubaru Posted May 23, 2005 Share Posted May 23, 2005 my 86 gl 4x4 wagon is wearing on the inside but im pretty sure its because my back shocks are bad I hope! Link to comment Share on other sites More sharing options...
idosubaru Posted May 24, 2005 Share Posted May 24, 2005 someone else had this exact problem on an XT or XT6, saw it either here or at http://www.xt6.net. they found and fixed the problem but i don't recall the cause. Link to comment Share on other sites More sharing options...
MorganM Posted May 24, 2005 Share Posted May 24, 2005 Check all your bushings back there. One possible cuase. Link to comment Share on other sites More sharing options...
