NoahDL88 Posted May 25, 2005 Share Posted May 25, 2005 So bringing the "water wagon" to a stop from 90 is about as fun as a can of bees, so i'm hopeing to do the vented rotor and caliper swap. 1. has anyone done this 2. What parts are needed? I know caliper and rotor, but do i need the backingplate? Knuckle? 3. Are the master cylinder's the same? 4. If you have done this, and know what parts are needed and are going to be at the WCSS7 and want to bring parts let me know the price. Link to comment Share on other sites More sharing options...
mcbrat Posted May 25, 2005 Share Posted May 25, 2005 my old Mountain Grizzly had the swap done before I got it, and Igot all the original stuff with it, but no backing plate, so I believe it's just the calipers, rotors, pads. with my current lifted 82 Brat, I stayed with the solid rotors. I don't have to worry about mud getting in and making them unbalanced... Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 25, 2005 Share Posted May 25, 2005 All you'll need is calipers, rotors, and backing plates. The reason why calipers are needed is because they are slightly wider then the solid style to accomidate the vented portion. You can even adapt them onto a gen 1 as well:D Link to comment Share on other sites More sharing options...
NoahDL88 Posted May 25, 2005 Author Share Posted May 25, 2005 All you'll need is calipers, rotors, and backing plates. The reason why calipers are needed is because they are slightly wider then the solid style to accomidate the vented portion. You can even adapt them onto a gen 1 as well:D The calipers were obvious, but thats currently one vote for backing plates, and one vote against. Link to comment Share on other sites More sharing options...
Hodaka Rider Posted May 25, 2005 Share Posted May 25, 2005 One of my parts cars was a little bastardized when I got it. It had one caliper from a vented rotor car, and it fit with non-vented backing plates. You might want to check into part #'s on the pads, too. Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 26, 2005 Share Posted May 26, 2005 well I'm not sure if the backing plates will need to be swapped since I did the swap on an EA71 car, not an EA81 car. Link to comment Share on other sites More sharing options...
